Need help cause I have NO CLUE.....
Old Dec 27, 2007 | 09:41 PM
Vidman's Avatar
Car: '86 Iroc
Transmission: T-5 with Pro-5.0
Hi Guys... I have an '86 Iroc and this site has been priceless during the restoration so I am here to ask for help yet again...
I want to help out my audio system, which right now is no amp with a JVC KDSX770 head unit (50 watt x 4), two Boston Acoustics plate speakers under the dash cover and two boston acoustics 6x9 FX93 3-ways in the backseat that read Amp Power 15-75 watts and 4 ohms. I want to increase my power and sound quality at higher volume, but am not looking for a real strong system, only want to rock with the t-tops out. I found on e-bay a new boston acoustics amp (can you tell I love boston acoustics??) that is a 4 channel amp that puts out 45x4 RMS @ 4ohms. Will this do what I am looking to do, or do I still need more power? I have been told that the 50x4 I have now is not putting out anywhere near the 50 it says, but that RMS is the actual wattage? Anyway, as you can see I am pretty much clueless on modern audio equipment, but I know with your help I can get it right! Thanks in advance and God bless!!
Old Dec 27, 2007 | 11:41 PM
4playta's Avatar
Car: 1984 Trans Am
Engine: Built chevy 350
Transmission: TCI Built 700r4
Axle/Gears: 3.73 posi 10 bolt
Re: Need help cause I have NO CLUE.....
A 45x4 rms amp will sound a million times better then your deck powering your speakers...rock on!
Old Dec 27, 2007 | 11:49 PM
killercatcher24's Avatar
Agree with guy above if thats all power u want out of it, I like Bass but thats just me, anyways to help u out when buying a amp dont go off of the total watts go off of the rms watts. and a amp would be alot better then the jvc i preffer a good kenwood or alpine deck that u can find for bout 85-130 dollars and sound good witout amp but thats up 2 u
Old Dec 28, 2007 | 02:55 PM
Vidman's Avatar
Car: '86 Iroc
Thanks guys. It is a good feeling knowing anytime I have a question I can come here for the answer!!
Old Dec 28, 2007 | 05:14 PM
Vidman's Avatar
Car: '86 Iroc
One more question (for now...)
I am looking at a BA GT-40 which is a 4 ch amp with 45x4 rms, but now I saw a GT50 which is a 5 ch amp with 45x4 plus 1x190, I don't have a sub, but should I consider this setup instead of just the 4 channel?? OR maybe I'd just be better off getting the GT42 which is 70x4 rms?? This would be easier if they only made ONE KIND!!!!!!!!!!!!!!
Old Dec 30, 2007 | 03:10 PM
irishhockey34's Avatar
Car: 92RS
Engine: LQ4
Transmission: 4L80E
all three will do the trick. If you plan on maybe adding a sub woofer later, i would buy the 5 channel just to be safe. But other than that its completely your choice.
Old Dec 31, 2007 | 06:11 PM
Vidman's Avatar
Car: '86 Iroc
Thanks Guys!!!!
David Trimble
Oct 26, 2003 07:41 PM
