any one use this amp?
Old Feb 6, 2008 | 09:41 PM
305blackbird's Avatar
Car: 1987 pontiac Trans Am
Engine: 1988 305 TPI
Axle/Gears: 2:73 ... I think
anyone use this amp..... what do u guys think for a basic system for a guy that listens to country and can get it new in the box for 40 bucks 420W max Jensen amp420W MAX; NOMINAL OUTPUT POWER: 75W X 2 @ 4?; 210W X 1 @ 4?, 110W X 2 @ 2?; 2? STABLE; VARIABLE LOW PASS FILTERS 40 HZ–240 HZ (12 DB PER OCTAVE); VARIABLE HIGH PASS FILTERS 40 HZ–400 HZ (12 DB PER OCTAVE); VARIABLE BASS BOOST 0–12 DB @ 45 HZ; LOW-LEVEL PASS THROUGH RCAS POWER & SPEAKER CONNECTORS; CHANNEL-MODE SELECTOR SWITCH (4/3/2 CHANNELS) BRIDGE- / TRI-MODE CAPABILITY; PROTECTION CIRCUIT THAT SAFEGUARDS AGAINST SHORT CIRCUITS, DC-OFFSET & THERMAL OVERLOAD; GREEN OPERATION & RED PROTECTION LEDS; BLUE ILLUMINATED VU LEVEL METER & LOGOS
Old Feb 6, 2008 | 11:24 PM
Jeff91RS's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: World Class T-5
Axle/Gears: 3.27 9-Bolt LSD
Re: any one use this amp?
i worked for circuit city as an installer and we sold that line of amp and it was decent for the price, but nothing special.
Old Feb 7, 2008 | 10:48 PM
terrorhertz's Avatar
Car: '88 IROC
Engine: 305 TBI LO3 for now
What are your plans for the amp? What speakers do you plan to drive with it?
It is a 2 channel amp that is 2 ohm stable. So you could run a rear box or sub or you could run 2 or 4 speakers in stock locations off of it. If you run 4 4ohm spaekers front and rear then you'll give up fader control.
If your looking at getting another amp then it opens up a lot more possabilities.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
