annoying whine
Old Feb 24, 2008 | 04:16 PM
mellis09's Avatar
annoying whine
ok i know if i get the annoying whine my power cable is too close too my audio cable.. is there anything i can buy or put around the cables so i can leave them where they are but get rid of or even reduce the whine?
Old Feb 24, 2008 | 04:57 PM
Jeff91RS's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: World Class T-5
Axle/Gears: 3.27 9-Bolt LSD
Re: annoying whine
assuming your noise is coming from what you have the amp hooked to then buy a ground loop isolator
go to anyplace even walmart and they have them, or of you are strapped for cash i have seen people ground the outer connection of the rca to the body and that removes alot of wine, also most people dont think about it but the power cable you just ran isnt close to the only source or electrical noise in a car, there is alot of stock wiring that may be near your rcas too
Old Feb 26, 2008 | 12:21 AM
Sclary18's Avatar
Car: 83 Slomaro
Engine: 383 Stroker
Transmission: 5 Speed
Axle/Gears: 4.10
Re: annoying whine
you need to run the rcas by themself on the other side of the car. thats the only way to solve it
Old Feb 26, 2008 | 11:02 AM
Rally Smith's Avatar
Car: 91 RS
Engine: 305 TBI
Axle/Gears: Factory 2.73 (unfortunately)
Re: annoying whine
Make sure the power wire is nowhere near the plug wires. That will cause you problems as well.
Old Feb 26, 2008 | 05:01 PM
cdoyle's Avatar
Re: annoying whine
Have you verified that the sound is coming in through the RCA's? Unhook the RCA's and see if the whine goes away.
If it's still there, then take a look at your ground wire. Make sure it's connected to a clean piece of metal, and try and keep your ground as short as possible.
GTAman
Jul 3, 2024 07:29 PM
Infested
May 22, 2018 11:56 PM
thejimsterz28
Sep 30, 2015 08:52 PM
Youngs92
Sep 23, 2015 11:29 AM
PATRIOTIC1911
Sep 1, 2015 07:26 PM
