Subwooder with no preamp output?
Subscribe
Mar 1, 2008 | 09:11 PM
I have a cheap *** sony headunit. Its nothing but the wiring harness for 4 speakers and an antenna. I only run 2 6x9's so I do have outputs open.
I bought a 2/1 channel 250w amp with the plans to run a 10in sub off of it. The only thing is that now I dont know how to output to my sub. I'm guessing I should take my 2 speaker outputs that I still have and splice them into an RCA cord to plug into my amp?
I guess there will be no nice on headunit sub controls this time round...
Does that sound like the right thing to do?
Reply 0
Mar 1, 2008 | 09:35 PM
Re: Subwooder with no preamp output?
http://www.amazon.com/PAC-SNI35-Adj-.../dp/B0002J22AA
I had one installed in my dads s10 xtreme. Local audio shop carried it and works perfectly. I could have done the install myself but didnt feel like it lol.
just connect speaker wires from radio to this unit and connect your rca cables from this to amp.....im gonna use it for my 95 t/a when i get it out of storage
Reply 0
Mar 1, 2008 | 09:39 PM
Does that filter out high frequencies too?
I'm definatly gonna have to pick one of them up rather than hacking up wires.
Reply 0
Mar 1, 2008 | 09:54 PM
"ADJUSTS THE SIGNAL FROM 2W TO 40W PER CHANNEL WITH SIGNALS BELOW 20 HZ CUT-OFF"
Im not an expert but i think thats a yes from site
Reply 0
Mar 1, 2008 | 10:02 PM
Lol thanks man. I can hook it up but beyond that I cant wrap my head around it.
Reply 0
Mar 1, 2008 | 10:08 PM
Wait signals below 20hz? What hz are subs designed for? I thought bass = low hz's
Reply 0
Mar 1, 2008 | 11:20 PM
Quote: Wait signals below 20hz? What hz are subs designed for? I thought bass = low hz's
20hz is high pitch(hurts your ears)=tweeters
then other end
20 khz is lows(bass)=subs/nice 6x9s
least thats how a buddy just told me......also went and got a cd that has a audio test for cars.....
called 20 hz to 20khz......goes from ear spiltin to bass pounding
Reply 0
Mar 1, 2008 | 11:52 PM
You have that backwards my friend:
20 Hz would be bass, or low frequency
20 KHz would be tweeter, or high frequency
Hz = cycles per second
The more cycles per second, the higher the frequency.
EDIT: That unit does not act as a crossover, it is a converter. The high frequencies
will still pass through.
You can use an inductor (passive filter) to cut of the high frequencies to
the sub.
Reply 0
Mar 1, 2008 | 11:59 PM
oh ok thanks lol, so then what does it mean it cuts off after 20hz? it plays awesome bass in dads truck......
Reply 0
Mar 2, 2008 | 12:16 AM
THat page is full of typos. Here's another page:
http://www.sjgreatdeals.com/tb-sni35.html
Anything under 20 Hz is cut off because the human ear cannot detect
them. Most amplifiers and head units have frequency ranges of 20 Hz to
18 Khz (some up to 20 Khz or more).
The bass range is said to be 20-180 Hz. THat is why your dad truck stereo
is able to produce good bass tones.
Reply 0
Subscribe
