Rear sound only?
Old Mar 17, 2008 | 07:43 PM
t/agta's Avatar
Car: 87' Trans Am GTA, 88' Trans Am GTA
Rear sound only?
ok so before i got my new headunit, the stock one was all static when you got about 1/4 way up on the volume. I put my new JVC headunit in, and i have to put it all on the rear speakers. I i put anything on the front, All four speakers AND my subs are static. I cant find any problems in the wiring, i plugged a different head unit in, i took all four speakers out and bench tested them one by one. I have no clue whats going on. Any ideas?
Old Mar 31, 2008 | 03:08 AM
Jeff91RS's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: World Class T-5
Axle/Gears: 3.27 9-Bolt LSD
Re: Rear sound only?
sounds odd, seems like u checked it all, did u test the wires? check for resistance, wiggle em around might be shorted out. its not too hard you could just run new wires to the fronts
Old Mar 31, 2008 | 04:11 AM
titan's Avatar
Car: 1990 Camaro RS
Engine: L03 305 TBI
Some of the GTA's offered a sound package that included a factory amp. Sounds like that's what you've run into. Do you have a "slider" type gain control to the left of your defroster panel? If so, you have the sound package. The factory amps are in the dash, and can be bypassed there, but for the sake of not hacking anything up (those are pretty rare setups) I would recommend running a new wire to each speaker from the headunit.
Now when you refer to the subs, are you talking about the ones in the sail panels, the 4" factory ones? Or do you have an aftermarket set? If it's the ones in the sail panels, you will need to series the rear speakers, and then connect them to the head unit. If you don't you will present a 2ohm load, and the deck will "clip" or cut out intermittently. Post back with what you have, and we can go from there.
Frozer!!!
Jan 19, 2024 04:55 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
db057
Aug 22, 2015 08:17 PM
midias
Aug 22, 2015 01:42 AM
