Audio newb. Most likely an easy question for you guys.
Old Mar 21, 2008 | 07:15 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
The audio system in my IROC is stock (not bose). The only modification is a Sony CD player. After some searching here, I purchased INFINITY Kappa 693.7i 3-way 6x9 Speakers.
They come with 2-way external crossovers. I believe that's what I have circled in green here:
Do I need to hook them up? I thought you only need to use those if you have an amp? I figured all I had to do was take out the old 6x9's, and put the new ones in. Then attach the wires the same way. Any help would be appreciated.
Old Mar 21, 2008 | 08:12 PM
Jeff91RS's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: World Class T-5
Axle/Gears: 3.27 9-Bolt LSD
Re: Audio newb. Most likely an easy question for you guys.
ive never installed kappa but most non component speakers with the external x-over they are pre wired and all u do is stuff them in the cavity, but yes if you dont use them u will either only use the woofer or tweeter(s). if u do have to wire em its not a big deal pretty much speaker input from radio on one side then there is a woofer out and a tweeter out, i recommend zip tieing or something so they are secure in your side panel
irishhockey34's Avatar
Car: 92RS
Engine: LQ4
Transmission: 4L80E
if you bought component speakers then yes, you will need to use the crossovers. they separate the highs to the tweeters and lows to the 6x9. its quite simple to install. just a + and - in and two + and two - out. One pair to the 6x9 and one to the tweeter
Old Mar 21, 2008 | 08:41 PM
Car: 1988 IROC-Z
Engine: 427 SBC
Awesome! I see I have to use them. Thanks guys! Much appreciated.
1992Vortec
Aug 31, 2015 08:05 PM
z28_AJ
Aug 27, 2015 08:59 PM
355tpipickup
Alternative Port EFI Intakes
Aug 22, 2015 06:06 PM
Jake_92RS
Aug 17, 2015 09:42 AM
redmaroz
Aug 16, 2015 11:40 PM
