radio dosen't work
Old Apr 19, 2008 | 11:02 PM
Grizzlybear226's Avatar
Car: 1988 Trans am
Engine: 358
radio dosen't work
ever since i replaced my fender my radio hasn't been working right.all we did was lower the antenna on the car and then raised it back up, i can't figure why its not working, i've adjusted it 5 times already.everytime i do it sounds great and all the stations come in when i'm sitting still, then as soon as i start driving it will come in crappy.what could it be. its a 88 trans am with a non electric antenna
Old Apr 20, 2008 | 12:26 AM
vinman75's Avatar
Car: 94 c1500 ecsb
Transmission: 4l60e
Axle/Gears: 3:73
Re: radio dosen't work
only thing i can think of is the antenna is not grounding well enough to the bottom side of the fender, is there a thick coat of primer or paint under there?
Old Apr 20, 2008 | 09:43 PM
Jeff91RS's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: World Class T-5
Axle/Gears: 3.27 9-Bolt LSD
ground sounds suspect, but on the standard automotive antennae plug the inner pin is the ant and the outer is a chassis ground, so theoretically plugging the ant lead into the back of the radio is giving the ant ground, im assuming its a power ant. one possibility is if you replaced your ant because you got into a literal fender bender it may have jarred the ant internals and when in motion some circuit is broken, its a stretch but im just trying to help. never put it past the radio to go out radio to go bad at the perfect time that you think its something else.
Old Apr 20, 2008 | 11:20 PM
vinman75's Avatar
Car: 94 c1500 ecsb
Transmission: 4l60e
Axle/Gears: 3:73
yes but if you meter a standard antenna before plugging it in to radio, it is grounded. Thats why I think there may be an issue in that fender.
Old Apr 20, 2008 | 11:30 PM
Jeff91RS's Avatar
Car: 91 RS
Engine: 350 TBI
yes because they are typically mounted to a metal surface but in the instance of universal(brick style) hidden ants or a lot of luxury grid style ants they don't do not ground. if an ant doesn't ground anywhere other than the radio it will still get reception just fine, as long as the radio is properly grounded
Old Apr 22, 2008 | 10:42 PM
Car: 1988 Trans am
Engine: 358
i figured out what it was, it wasn't grounded enough to the fender.thanks for all your help.now all i have to do is finish the paint
Vintageracer
Jan 10, 2020 05:33 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
