Good system for my bird.
I have an 86 firebird that needs some speakers and a new head unit. I am looking into a Sony head unit and infinity speakers... But what kind/size speakers do I need? 6x9s and 4x6 ??? I need the ones in the dash pad and the rear sails. (don't want any fancy subs or amps just good quality sound for the zepplin) I listen to mostly rock.
Thank you so much as I am an idiot when it comes to this stuff.
Car: 86 bird
Engine: LG4
Transmission: A4
Re: Good system for my bird.
im pretty sure it is 6x9 in the back and 4x6 in the front i need some also. im thinking about getting rockford forstgate or polk
Car: 1984 camaro z28
Engine: L69 H.O
yep 6x9 for back and 4x6 for front and what ever you buy make sure you check the magnet size on the speaker because if its too big it wont fit
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
Make sure your 4x6 mounting depth does not exceed 1.75 inches. As it is, the 1.75' (atleast on my camaro) doesnt clear the instrument cluster. (drivers side) To make room for the risen speaker due to bottom fitment issues, I have cut out the speaker grouves in the stock dash mat and put a vinal aftermarket reproduction pad with flat speaker vent holes that do not dip to reduce speaker area under the dash mat.
Car: 91 RS
Engine: 383 Stroker 450HP
Transmission: TH350 3500 Stall no OD
Axle/Gears: 30 Spline Axles 4:10 gears
hit up a pawn shop, you can usually score car speakers for cheap there.
9192camaro
16
Feb 3, 2019 12:21 AM
backtothe80s
Sep 5, 2015 12:39 AM
Street Lethal
Aug 13, 2015 08:28 PM
