Stock radio losing memory.
Old May 24, 2008 | 04:42 PM
ken3983's Avatar
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
I have a stock factory 1991 radio for my '91 Camaro. Every few days or so, it wants to lose the staions in memory. I can't see a bad fuse because it would either keep the memory or not at all. Power drain does'nt seem likely because the car starts fine. Anyone run into this?
Ken
Old May 26, 2008 | 09:20 PM
regal1975's Avatar
Car: 1984 T/A
Engine: 327
Axle/Gears: 3.23:1
Re: Stock radio losing memory.
pull the radio and check the orange wire for constant 12v... this is your constant wire which will maintain your radio presets... since this isnt a situation where you lose them every time you shut off, it may be harder to test.. I would suggest running a new wire to a fused 12v constant source and see if the problem persists... if it does, then it is the radio itself.
Vintageracer
Jan 10, 2020 05:33 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Winchester1094
Interior Parts Wanted
Aug 19, 2015 05:01 PM
arod231
Aug 16, 2015 02:51 PM
Spd-Kilz
Aug 15, 2015 12:12 PM
