Wattage question..
Old Jun 21, 2008 | 09:59 PM
83' maro's Avatar
Car: 1987 IROC-Z Camaro
Engine: LB9 305, edelbrock intake.
Axle/Gears: 10 bolt, 3.73 posi w/ disc brakes
Wattage question..
So I have two Alpine 10: 1042 dual voice coil 4 ohm subs that require 500W RMS. If I want to run both of them in a 4ohm setup to get the best audio clarity and hard hit (from what I've read) I will need a single channel amp that will distribute 1000W X1 at 4ohms? I've been trying to do all my research for awhile on power distribution but I just had that quick question. Thanks guys/gals!
Old Jun 21, 2008 | 10:12 PM
acadburn's Avatar
Car: 1989 Camaro RS
Engine: 305 V8
Re: Wattage question..
well my question is dose the set need 500rms or each sub need 500 rms
but if you wire each 4 ohm sub's voice coils in parell you can wire the subs in series that would give you a 4 ohm load over all
if the set takes 500 wats RMS then a 500 watt AMP is what your going to want
some people would get a 2 channel amp and bridge it others would get a mono block amp and run it that way its kinda like 12 or a dozen its whichever you can get your bang for the buck out of
Old Jun 22, 2008 | 10:40 AM
83' maro's Avatar
Each sub requires 500W RMS
Old Jun 22, 2008 | 12:34 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
You could get an amp that can put out 1000 watts RMS and is stable at 1 ohm (doesn't have to be that high - a good 500 WRMS amp would do). Wire your subs parallel so you present a 1 ohm load to the amp. Probably get those subs to hit pretty hard with that configuration.
Here are a couple of wiring options for you, one is for a 4 ohm load, the other for a 1 ohm load.
http://www.the12volt.com/caraudio/wo...s.asp?Q=2&I=42
Old Jun 22, 2008 | 02:25 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
An amp that is 1 ohm stable is going to cost more than one that isn't...
If each sub can handle 500 watts rms, I'm assuming 250 each voice coil... Each voice coil is 4 ohms, wire 1 voice coil to another in series, (8 ohm) then wire the 2 subs up to the amp parallel (4 ohms)... If you have a 1ch mono amp...
2 channel amp? Find a 2 ohm stable one... or one that can bridge to 1 channel 4 ohm. Or a 4 channel 250watt rms amp would work too...
As noted, as ohm load decreases, distortion usually goes up...
Raf
Old Jun 22, 2008 | 06:31 PM
83' maro's Avatar
Thank you everyone for your posts. I got the HiFonics brutus 1606D amp and will be wiring the subs to a 1ohm configuration.
Fronzizzle
Aug 19, 2015 01:36 PM
di11avou
Car Audio
Nov 7, 2002 12:12 AM
mike graycar
Oct 6, 2002 01:45 AM
Bluebird
Apr 23, 2002 09:39 PM
KeithO
Car Audio
Jan 14, 2002 10:48 AM
