speed control volume retro fit question
Old Jul 28, 2008 | 10:13 PM
DeanJ's Avatar
Car: 1988 Camaro, 1986 S10, 2000 Harley
Engine: LS6
Axle/Gears: 3.75 9" ford trac loc
Hi Guys,
I installed a 4th gen Delco radio with the SVC in my 1988 Camaro. I need to know if the SVC can be made functional with the optical speed sensor. This system does not have the VSS buffer. Could the brown wire to pin A-10 on the ECM be used for this? Thanks in advance. Dean!!!
Old Aug 1, 2008 | 07:31 AM
DeanJ's Avatar
Engine: LS6
Re: speed control volume retro fit question
Come on guys,somebody has to know. Dean
Old Aug 1, 2008 | 11:02 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
That's the wire I tried to use on my 89 and haven't got it to work yet. I've seen a post a long while back where this was hooked up and worked just fine. Being a "newer" radio, I think maybe 2000 pulses per mile is too low from my TBI VSS, or the function in the radio is defective. I do believe the TPI and V6 MPFI VSS puts out 4000 pulses per mile.
Frozer!!!
Jan 19, 2024 04:55 PM
colton_carlson
Mar 8, 2019 12:21 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
BBSDesigns
Aug 11, 2015 07:39 PM
