500w Amp help?
Old Sep 3, 2008 | 10:17 PM
Mailbox Hunter's Avatar
Car: 89 Camaro RS
Engine: 350 TBI
Axle/Gears: 10 bolt/ 3.23 Gear.
500w Amp help?
How safe is keeping a small 500w Rampage amp in the trunk glove box? Im worried about it over heating in there, or is it cool?
Yes I know 500w is weak,
but I don't need my nice third gen "vibrating to hell"
any advice?
Old Sep 3, 2008 | 11:18 PM
Tehsocks's Avatar
Car: 85 Camaro Z28
Engine: 6.0L LS
Transmission: T56 Magnum
Re: 500w Amp help?
Assuming it can fit in there, it shoudl be fine. Small amps dont usually heat up much.
Old Sep 3, 2008 | 11:35 PM
Car: 89 Camaro RS
Engine: 350 TBI
Re: 500w Amp help?
thanks, Ill give it a go then
Old Sep 4, 2008 | 08:51 AM
kcidmil's Avatar
Car: 88 Camaro Sport Coupe
Engine: 2.8L V6
Transmission: 5 Spd
Re: 500w Amp help?
If you have a problem of overheating, i would look at installing a simple computer case fan into the side of the pocket
You can either wire in a switch for it, or my recommendation is to get a 12v relay, and wire that in and use the remote for the amp to turn it on.
This would require you to cut some holes in the trim piece, but for the sake of saving an amp it would be worth it.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
