My fiberglass box project
Old Sep 23, 2008 | 01:35 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
I started this last week, I figured I'd post it up. The bottom/frame is made from 5/8" MDF, with a contoured lid to fit snugly against the hatch plastics. It lines up with the trim line in the rear plastics, which goes all the way around. I cut the speaker rings using a router with a circle jig, and stretched fleece over the top and back. I've soaked the fleece with fiberglass resin, and let it cure overnight. I'll do 3 or 4 layers of CSM fiberglass over this, then wrap it with tan vinyl to match the rear plastics. What do you guys think? Also, any tips on vinyl wrapping are much appreciated, I may try using contact cement to glue it down.
Old Sep 23, 2008 | 03:11 AM
MilitantKustoms's Avatar
Re: My fiberglass box project
real nice job i used some fabri-tac or somethin like that its in the fabric isle at wal-mart it is pretty runny so it lays down flat and bonds good and quick to a simi-rough surface but dont use a thin fabric and dont use mass amounts or the glue wil just eat the fabric up literaly and you will have to start over also lay it down and leave it there if you try to move it youll rip the fabric ive been there so test it out first towards the bottom where you cant see it but I was trying to wrap the gauge bezle its got alot sharper curves and angles than a box so it should work good for you i did a box simular only its recessed down in the spare tire area and i was gonna paint mine and what kind of brush did you use just a regular brisle brush and could you reuse it i used a foam brush with the foam ripped off but the plastic insides are reuseable but make it kinda hard to work with
Hotrodboba400
Dec 10, 2019 07:07 PM
bubbaz28
Sep 18, 2015 02:09 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
SG91camaro
Sep 5, 2015 10:27 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
