Repair ANT coax cable?
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
I have a 1988 GTA with a power ANT. The connector on the ANT coax cable is broken and flopping around (connector that goes into the radio). Is there a way to splice a new connector on the end of the cable? Or, where can I buy an OE replacement ANT coax cable? Anyone have a GM PN? Anyone have an extra one? Looking for options to repair it...Thanks!
Car: 1984 camaro z28
Engine: L69 H.O
Re: Repair ANT coax cable?
if its anything like a tv coax cable you can just cut the end off strip it and crimp a new end on it i dunno though never cut apart an ant cable hope this helps
You can get the end at the local Radio Shack and it takes seconds to change. If the power antenna didn't work, I'd recommend just replacing the entire assembly with a standard fixed mast. The oem fixed antenna assembly with the cable is under $20 at the dealer.
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
Thanks guys. The antenna works well, well sort of. It goes up and down when wired direct to the battery, but when I wire it to the relay it no longer works? I kind of wanted to keep the power ant feature and get the bugs worked out. I'm sure it's the relay.
Another member just PM'ed me, he has a replacement coax cable for me. So, just the relay issue left to figure out!
Car: 1991 Z28
Engine: 355 TPI
Axle/Gears: 9 bolt disc / 3:27
I thought you just wired it into the 12volt for accessories and into the signal wire the ground... all connections right behind the stereo
Car: 1985 z28 camaro
Engine: 305 lg4,edelbrock,3"air cleaner.k&n
Transmission: turbo 700r4 w/b&m megashifter
Axle/Gears: Stock.
Most aftermarket stereo's have a power wire for connecting a power antenna,so when you turn the head unit on,the antenna goes up.Antenna ground usually goes to the body.
Alicat.
Alicat.
TMZIrocZ350
Oct 7, 2015 12:09 PM
