Sound system problem
Old Nov 23, 2008 | 08:02 PM
vargasjc's Avatar
I got 2 12" subs in my camaro RS..they are in a custom built box that goes where the spare tire usually does in the trunk...problem is...when i put the volume up high...the subs vibrations make the metal in the trunk , licence plate,etc make noises (making the music sound really bad)
so i can never really enjoy the system...my friend told me something about getting my trunk reinforced...i had never heard of that...can anyone explain it to me and about how much it would cost??
Old Nov 24, 2008 | 05:41 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Re: Sound system problem
I think your friend might be talking about using dynamat. Using dynamat will help keep vibrations down and improve sound. As for the license plate and other stuff, you will have to find out whats buzzing and vibrating so you can tighten things down or reinforce whats vibrating. Its common with a stereo system that things will vibrate or buzz. You can eliminate most of it but you will usally have some kind of buzzing.
Old Nov 24, 2008 | 08:59 PM
vargasjc's Avatar
about hoe much $$$???
Old Nov 24, 2008 | 10:53 PM
jermdm's Avatar
Car: 1989 Iroc-z
Not forsure how much dynamat is today. There are different kinds of dynamat and it depends on what you get and how much you want. You can get dynamat from local audio stores, here on the web, and ebay. Its sold in kits or sheets. The stuff helps dampen vibrations and buzzes and people claim the it will give you a few extra decibels from your system.
Old Nov 25, 2008 | 01:49 AM
zach113092's Avatar
I agree, Dynamat is the way to go, Im sure you can find better prices but just to give you an idea you can check this link. http://www.crutchfield.com/S-HvvHtq2...?brand=Dynamat
Old Nov 25, 2008 | 06:47 AM
vargasjc's Avatar
Thanks for your Help!!!
Old Dec 4, 2008 | 12:45 AM
antosh's Avatar
Car: 1991 camaro z28
Engine: 5.7 TPI L98
Axle/Gears: stock
do you have pitures of that sub box and did you build it or buy it somewhere and if possible to you have the measurments cause i was looking to put my speakers there but i cant seem to find anything that works good
and thanks
MustangBeater20
Oct 29, 2022 09:20 PM
db057
Aug 22, 2015 08:17 PM
gta power
Aug 13, 2015 06:15 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
