factory radio connectors?
Old Dec 22, 2008 | 05:19 PM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
are these the factory radio connectors? they were in my car, just laying there? not hooked up to anything.
did the factory radio have only the 2 6x9s?
Attached Thumbnails factory radio connectors?-connectors-001.jpg   factory radio connectors?-connectors-002.jpg
Old Dec 22, 2008 | 06:26 PM
vette gator's Avatar
Car: 85 Z28
Re: factory radio connectors?
Definitely don't look like connectors, but I have a different year (85). My car had the ERS system from the factory that has two 5 X 7's in the dash and two 6 X 9's in the sail panels. I've heard that not all 5 X 7 aftermarket speakers will fit the dash openings since there isn't a lot of room underneath.
Old Dec 22, 2008 | 06:47 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Those are factory Delco/Packard connectors for something but not the radio.
The original radios had 4x6 speakers in the top of the dash with mono radios and additional 6x9 speakers in the sail panel with stereo radios.
Old Dec 22, 2008 | 10:22 PM
ericjon262's Avatar
I'm puzzled then, any Ideas to what they might be?
Old Dec 23, 2008 | 09:48 PM
Dens71TA's Avatar
I think they may be A/C control connectors.
Old Dec 23, 2008 | 09:53 PM
ericjon262's Avatar
well, I thought of that, but the ac controls don't have anything that those would plug into.
could they be the connectors for a mono radio? they only had the two 4x6s right?
Old Dec 23, 2008 | 10:38 PM
Dens71TA's Avatar
I checked my '84 service manual and the diagrams for the A/C control head connectors look pretty much just like the connectors you have.
The connectors in the attached pic below are what was used on Delco radios from '78-88. Black is the radio power/ground/nighttime lighting/power antenna UP signal, white is front speakers, and blue is rear speakers. There is no difference in the connectors for mono and stereo radios.
Old Dec 29, 2008 | 07:51 PM
Dens71TA's Avatar
I was out where my '82 T/A is stored today and checked the wiring harnesses since they're out of the car. There's no doubt those are A/C control connectors. The single terminal is the fan blower power feed, the gray connector is for the fan speed switch, and the thin black connector is for the function rotary switch.
Old Dec 29, 2008 | 08:34 PM
ericjon262's Avatar
thanks, it's just weird though, I must have the wrong a/c controls or something, because I cant find where the plug in.
Old Jan 4, 2009 | 02:30 PM
Twin_Turbo's Avatar
The gray connector goes on the fan speed switch, the other one on the back of the rotary setting switch that's mounted on top of your heater control assy, visible if you pull the unit out of the dash
middian
Sep 5, 2015 01:42 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
Slush92RS
Sep 2, 2015 08:56 PM
SlowAZ28
Sep 2, 2015 05:19 AM
