capasitor question
Old Jan 12, 2009 | 04:00 PM
CodyC123's Avatar
Car: 86 Z28
Engine: 385
Transmission: T5 (soon to be in pieces)
Axle/Gears: 3.73 POSI Disc
capasitor question
ok so im new to hooking up this kind of thing and i wired my sub and amp without the cap. it worked fine but with it i had no power does it take time to charge or is it no good?
Old Jan 12, 2009 | 04:42 PM
mtwlkn122's Avatar
Car: 91 Firebird, 06 Dodge Ram 1500 SLT
Engine: 3.1L, 4.7L
Transmission: 700r4, 45RFE
Axle/Gears: 3.23 open, 3.55?
Re: capasitor question
Well to answer your question when u got your capacitor it should have came with a 1000 ohm resistor or something close to it which you use to charge it according to instructions. If you don't do this the right way you run the risk of failure(almost definite failure).
A capacitor is not efficient or worth your money these days. Except for the addition of some nice looking led lights they just arent worth the money. If your system is really hitting hard enough to draw power to the point where it dims your lights then i would go buy your self a power cell. Kinetik makes some amazing power cells and for 50 bucks more you can buy one that is over 100 farad instead of buying a 1 farad cap for your car. I personally am pushing two 12in subs each getting 500rms a piece from seperate amps. I hang out at the local car audio shop all the time and i can just say spend the extra money and get a power cell.
Sry for the long post but just as an example a friend of mine is running a 2000d and a 12in mojo in a 3.2 cubic foot box in his 04 impala. At a party he had it hittin for 4 hours almost straight with the car never being started or pluged in or anything. It was hittin loud and proud for a long time. Just as a side note a power cell is literally the size of a battery and also doesnt have all the fancy lights and looks. It plain and simple just does its job and does it VERY WELL.
^^if you cant tell i like my car audio equipment (also a salesman)
Old Jan 12, 2009 | 04:50 PM
CodyC123's Avatar
Car: 86 Z28
Engine: 385
ok thanks i didnt have the resistor you spoke of so i assume its trash
Old Jan 12, 2009 | 06:20 PM
mtwlkn122's Avatar
Engine: 3.1L, 4.7L
...before you chuck it..is it digital or just standard?...if its digital its easy to check to see if it will work
Old Jan 12, 2009 | 08:11 PM
CodyC123's Avatar
Car: 86 Z28
Engine: 385
thats a great question, unfortunatly i have no idea bought it used all i know is that its a lightning audio and it says .50 on it
Old Jan 12, 2009 | 09:14 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Not sure I've herd of a power cell. Sounds similar to an optima, and it probably just wires in parallel so as not to create 24 volts I assume?
Old Jan 12, 2009 | 09:17 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
A "power cell" is a low-capacity dry cell battery that's misnamed and misrated in farads for marketing purposes.
Old Jan 13, 2009 | 07:02 AM
mtwlkn122's Avatar
Engine: 3.1L, 4.7L
^^haha what he said. Like i said im a salesman tho. You know how it goes. Heres a link to there site.
http://www.kinetikaudio.com/
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
