Dash Speaker Fitment Question
Old Jan 12, 2009 | 09:44 PM
91RSinNS's Avatar
Car: 1991 Camaro RS Convertible
Engine: 305 V8 TBI
Axle/Gears: 4.1
I'm looking at doing some audio in the RS come spring...I'm examining my possibilities and have run into a stumbling block....According to Crutchfield, some 4x6's fit the dash, some don't...I cant tell a difference between them, though.
Specifically, these: http://www.crutchfield.com/p_065S75/...tics-S75.html?
Is there any reason those wont fit in the dash? If there is a clearance issue, is it as simple as heating up the heater duct pipe, or drilling a new hole in the speaker mount plate? Or would it be much more involved? I'd rather like to keep BA gear all through the car.
AR
Old Jan 12, 2009 | 09:59 PM
blackandgoldl69's Avatar
Car: 1984 camaro z28
Engine: L69 H.O
Re: Dash Speaker Fitment Question
the reason some will fit and some wont is because of mounting depth and magnet size just by looking at those i can say they should fit
Old Jan 12, 2009 | 10:02 PM
91RSinNS's Avatar
Engine: 305 V8 TBI
Axle/Gears: 4.1
Thats what I figured, too...I used Crutchfield to compare those to the 4" plates that they say fit (JLAudio's)...the mounting depth is 1/16" difference...and the magnet on the Bostons is a hair larger in diameter. So, I figured they'd fit....I just wanted to be sure there wasn't something obvious I was overlooking.
Thanks!!
Old Jan 13, 2009 | 02:48 AM
champnesupernva's Avatar
Car: 1983 Camaro Z28
Engine: 305, holley 4bbl. stock for now
Transmission: th200c, 700r4 coming in spring
if you get a 4x6 plate, you will getter a lower profile for definite fitment, and you will have a much better tweeter end. the mids will suffer just a bit, but it should be very clear. especially with good power.
Old Jan 13, 2009 | 12:37 PM
slow305rs's Avatar
They should fit but you will get better sound quality from plate speakers
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
89lsc
Aug 14, 2015 04:58 PM
