airspace-power?
Old Jan 21, 2009 | 07:52 AM
stang5.0killr's Avatar
Car: 89 camaro
Transmission: th350
airspace-power?
i need my memory refreshed, i can't remember if you will need more power for boxes with more airspace then the speaker needs or less power
Old Jan 21, 2009 | 08:48 AM
Civerus's Avatar
Re: airspace-power?
does it take more power to push air into a tire with 22psi, or 44psi?
44 = smaller box, less room, requires more power to push the air inside of it due to lack of room. 22 = larger box, takes less power to move air around a larger box due to increased room. not sure on this theory, but to me it makes sense. STAY AWAY FROM ME!!!
Old Jan 21, 2009 | 01:07 PM
-srs-'s Avatar
Car: 1991 Z28 Vert
Re: airspace-power?
Forget about box size and power. Match your box to the specs of the sub. Raw wattage is overated...mostly because most manufacturers don't accurately report their true output.
