amp neededd?
Old Feb 11, 2009 | 08:00 PM
grx45's Avatar
Car: 87 Camaro Z28
Engine: 355
amp neededd?
I am putting in an pioneer head unit putting out 15 watts rms per chanel. In the front i am putting in 4x6 pioneers rated up to 20 watts rms. So that works out fine. How ever in the back I want to put in alpine type r 6x9s. They are rated up to 100 watts rms. Can i run them with just the head unit or is that to underpowered for thee type r speakers.
Old Feb 12, 2009 | 03:58 PM
Civerus's Avatar
Re: amp neededd?
Run em with the headunit just fine, just use the fader to fade to the back a couple of levels so it sounds even all around.
Old Feb 13, 2009 | 12:09 PM
IROCKET4U's Avatar
Car: 1988 IROC
Engine: 5.7 litre
Transmission: Auto--700R4
Axle/Gears: 3.27 Posi with 4 wheel disc brakes
Re: amp neededd?
What you are doing will work but you will suffer in quality if you want to turn the volume up (And I dont mean cranked). Deck power will never give you really clean, undistorted sound. It would be money well spent to buy a $100-$150 amp and have a shop install it--Your sound quality will improve 100%.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
