IS IT WORTH 100 BUCKS?
Old Mar 1, 2009 | 05:50 PM
ROCFATHER's Avatar
Car: 89 IROC-VERT
Engine: TPI 305
Transmission: 700R4 Auto
Axle/Gears: 2.77
I'm close to buying a factory delco sterio for an 89 Iroc. This one is real clean and has the IPOD jack installed on it. Is it worth a 100$?????
Old Mar 1, 2009 | 06:38 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
Re: IS IT WORTH 100 BUCKS?
you could get one from a jy and clean it up for alot less then that
Old Mar 1, 2009 | 08:30 PM
Jeff91RS's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: World Class T-5
Axle/Gears: 3.27 9-Bolt LSD
well u will get more bang for your buck on a aftermarket headunit. if you are looking or a stock appearance u could get an WIRED fm modulator
audivox makes one for about 50, adv fmm100a
Old Apr 12, 2009 | 02:41 AM
BigBadJohn's Avatar
$100 is a little high. I was selling them on here for cheaper about a year ago. Most of my electronics gear, wire, and parts are at my parents house and I havent moved them over yet. I dont know if there are even many radios to choose from in the junkyard right now so I have no clue if I can even find any to modify
I just installed a Pyle PLMD-9 fm modulator in my corolla. I like it a lot. It has 110 channels it can broadcast on versus others that might have 7 channels if that.
Even has a remote and digital frequency display
Heres some pics after installation
Old Apr 12, 2009 | 07:08 AM
88TransAmFreak's Avatar
Car: 1971 Camaro
I'm close to buying a factory delco stereo for an 89 Iroc. This one is real clean and has the IPOD jack installed on it. Is it worth a 100$?????
If your griping about the price then it obviously isn't worth $100 to you.
Value is what a person is willing to pay, and how bad they need it. I'm sure there is someone out there that will pay that because they have a higher need for it.
My 2 cents...if it's clean (which are getting scarcer and scarcer), well taken care of and already has a aux plug in it......yes it's worth $100.
Junkyard radio w/o a aux input isn't even in the same class. I wouldn't pay more than $25 for one of those.
Old Apr 12, 2009 | 02:41 PM
Jeff91RS's Avatar
Car: 91 RS
Engine: 350 TBI
Couldn't agree more, when we were cleaning out a shop I worked at we found a stock pile of factory radios with atleast 15 of the j2000 (80s and 90s gm din and a half) radios that we just pitched cause they aren't worth squat.
Old Apr 13, 2009 | 10:30 AM
DarrensCamaro's Avatar
Car: 1992 Camaro RS
Engine: 350 Carb'd
Transmission: 5 Speed
I'd say its prolly worth $100, but if you dont mind going aftermarket that would be you better idea. But I assume your doing this to keep the stock look?
69GTOby
Apr 18, 2016 02:34 PM
kitt23
Nov 4, 2015 05:40 AM
jerflash
Sep 24, 2015 03:11 PM
jerflash
Sep 23, 2015 09:21 AM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
