Ford Speaker/Tweeters in window triangle
Old Mar 27, 2009 | 04:01 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
As you all know, our thirdgens were not designed for optimized radio sound distribution through the cabin. Many of us add "better" speakers upfront but you all know most of the time, most audio comes from the 6x9's... My girlfriend has a Ford Taurus and it seems Ford has a good thing going (along with most newer cars) having small speakers on the window triangle. So I though why not do that to my Trans Am. Prior to the window install, I already had 10 speakers in the car. The 2 on the dash (Pioneer), the 2 6x9's (XPLOD), an additional 2 6x9's in the hatch area (Pioneer) 2 6 1/2's in the doors themselves and the 2 12's (Kickers). Everything sounded great powered by 2 amps. But I figured why not add these 2 little speakers. After the install, all I have to say is WOW. It really makes a world of a difference. Mainly because they are so close and at level and pointing at you. At first I thought they were just tweeters but I took them off to inspect and they're actually tiny 2 or 2.5 speakers. I took them off a Mercury Sable and they are the "Mach Audio" version which I believe is Ford's version of the "Monsoon" system. The install wasn't has hard as I thought. I had to cut it down to the actual triangle and got rid of the mounting lips/edges. Only used 3 bolts. 2 on the bottom and 1 on the back. The one on the back bolts into the rubber on the triangle. Theres a little nich/tunnel where the window slides in. The one on the rubber doesn't affect the window at all. I need to go back and paint that one black so its not that noticeable. There is a slight indent on the dashpad but nothing too bad. I already have the Autometer 3 gauge pod which puts an indent already. The only 2 things I need to fix are the backing. I think I'm going to get some plastic and cover the back fo the speaker housing (since you can see into it at the moment). And I want to get a sticker that says "Performance Sound" instead of "Mach Audio"... Here are some pics. Excuse the pollen and dust. Seems the trees are mating all around. For some reason, it looks much better and more stock in person than it does in the pics.
ps.for those you that will start complaining "I would never put a Ford part in my car"...get over it. I'm a hot rodder and thats what hot rodding is all about; mixing and matching different car parts to make yours unique...
Attached Thumbnails Ford Speaker/Tweeters in window triangle-100_2279ed.jpg   Ford Speaker/Tweeters in window triangle-100_2280ed.jpg   Ford Speaker/Tweeters in window triangle-100_2284ed.jpg
Old Mar 27, 2009 | 04:02 PM
HCR13's Avatar
Car: 1987 Trans Am
Re: Ford Speaker/Tweeters in window triangle
Last pic
Attached Thumbnails Ford Speaker/Tweeters in window triangle-100_2278ed.jpg
Old Mar 27, 2009 | 04:53 PM
Slave One's Avatar
Car: 1991 Camaro RS
Engine: 5.0 TBI
Axle/Gears: 3.08
Props to you man, VERY cool idea!
So they sound pretty good, eh? What are they typically called so that I may find me some?
Old Mar 27, 2009 | 06:49 PM
ClickClickVroom's Avatar
Car: 92 Z03 RS TBI
Engine: 5.0 L03
Anything we can use from the yard that doesn't stick out that much? and do your windows get scratched by the bolts?
Old Mar 27, 2009 | 09:19 PM
HCR13's Avatar
Car: 1987 Trans Am
I'm not sure what they would be call... I just type in "Ford tweeter" on ebay and I get alot of hits...
As far as sticking out, I'm not sure, I just looked specifically in Tauruses and Sables since my girlfriend had one. I think the Mustang's doesn't stick out as much but there aren't any newer gen Mustangs around here... I think newer GM vehicles have them aswell...
It doesn't even touch the window at all since the window presses up against the outside edge of the triangle and the bolt pulls inward. It DEFINITELY is worth doing if you enjoy hearing music clearly even with the windows down!
Old Mar 28, 2009 | 10:31 AM
TheMuskr's Avatar
Car: 89 IROC Z28 Vert
wow looks great
Old Mar 28, 2009 | 10:57 AM
885speed's Avatar
Car: 1988 Camaro
Engine: LR4
Axle/Gears: 3.23posi/disc
Great idea, my only change would be to find a smaller one that wont sit kind of awkwardly...
My input:
After seeing your pictures, it reminded me of my buddies 99GT with the mach system, it had door triangle tweeters too... and if I remember right, they were a bit more compact.
Old Mar 28, 2009 | 01:44 PM
88TransAmFreak's Avatar
Car: 1971 Camaro
You can get the same effect by taking some 3/4" mdf, cutting out a tringangle pattern to fit that area, router the edges round and cover the whole thing with grill cloth.
Just flush mount the tweeter before you cover it, then attach it to the triangle
This is what I did instead of the triangle, coupled with a set of 6.5" mid basses in the doors it's all I need.
Old Mar 28, 2009 | 03:06 PM
HCR13's Avatar
Car: 1987 Trans Am
Thats not bad. I too have some 6.5's in the door pods and these still made a difference. I think the dash idea is cool, but my only problem with that is the sound still has to bounce of the windshield to get to you. The triangle mounts give uninterrupted sound...
If I find some Mustange triangles, I think I'll for those instead too...
Old Mar 28, 2009 | 09:26 PM
885speed's Avatar
Car: 1988 Camaro
Engine: LR4
If my woodshop teacher comes back from his hip surgery before I forget about this, I'll come up with some sort of design out of wood and see where i can take it.
Gotta give credit where its due though, this is a great idea HCR13!
Old Mar 29, 2009 | 12:33 AM
HCR13's Avatar
Car: 1987 Trans Am
Thanks, but I think its a pretty common thing on most newer cars... I'm surprised no one thought about putting those in a thirdgen... I recommend finding some OEM speakers that go in that area, from Ford or GM or Dodge, doesn't matter. Speakers that small are hard to blow...
Old Apr 4, 2009 | 03:55 AM
ellocojorge's Avatar
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
do u have any picture of the 6 1/2 on the door?
Old Apr 4, 2009 | 12:49 PM
HCR13's Avatar
Car: 1987 Trans Am
yeah, but they are REALLY CRAPPY. I literally just bolted them on, no housing, no pod, just speakers bolted the door panel with long bolts... if you do a search, you should be able to find nice settups where people actually used fiberglass or MDF boards...
Old Apr 4, 2009 | 01:20 PM
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
i want to do wat u did, but use component... but im not sure what part of the door to attach them too, or wether to go with 6.5 or 5.25 speakers
Old Apr 5, 2009 | 08:39 PM
injdinjn's Avatar
Car: 1986 Grand Prix TPI
Transmission: 200 4R
New GMC's with the Bose system have A piller speakers - not available from Bose though.
Old Apr 14, 2009 | 08:58 AM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
my girlfriend has a mustang with the mach audio system, and i can tell you, hers stick you a lot more than yours do.
granted, there is a spot for them to fit into, but its obvious that they are there.
know what i mean?
good job.
Old Apr 14, 2009 | 01:29 PM
HCR13's Avatar
Car: 1987 Trans Am
yeah, I would get Mustang speakers if there was one at the junkyard... but all they had were the Sables and Tauruses...
Old Apr 14, 2009 | 03:57 PM
Car: 85 Camaro IROC
Engine: 5.7 TPI
the mustang ones (and i presume the sable and taurus versions as well) are pretty nice components.
my GF's car has two amps to power the whole system (8 or 10 speakers)
i believe its got the two in the dash, two in the doors, two in the back glass area, two in the elbow rests in the back seat, two tweeters in the front.
i think thats it.
Old Apr 14, 2009 | 06:14 PM
HCR13's Avatar
Car: 1987 Trans Am
yeah, that sounds about right...
Old Jun 1, 2009 | 06:38 PM
picasso_88's Avatar
Car: 1986 Firebird
Engine: Chevy V8
My 99 Grand Prix GT has little tweeters similar to these mounted in the triangle area. But they look even smaller and dont stick out much. I might have to take them out and size them up one day...
Old Jun 1, 2009 | 07:53 PM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
off topic, but is that a daihtsu Rocky next your car I have always loved those never been able to find one for sale though....anyways sweet idea with the speakers
Old Jun 1, 2009 | 07:59 PM
HCR13's Avatar
Car: 1987 Trans Am
Eventually, I'd like to go back to the junkyard and look a little harder and fine maybe smaller ones...nothing wrong with these but a bit smaller wouldn't hurt...
92RS:...that sure is. I've never heard of the Rocky's until I started talking to my neighbor... he also has WRX STi, so he knows his cars...
Old Nov 4, 2009 | 05:16 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Going to resurrect this thread, its an awesome idea I would like to do someday. Has anyone found a speaker that might fit better ?
Old Nov 4, 2009 | 07:23 PM
HCR13's Avatar
Car: 1987 Trans Am
I'm not sure. I'm going to the junkyard tomorrow and I'll keep an eye out for better triangles...
Old Nov 6, 2009 | 08:28 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
the 97-03 Grand Prix' have a similar setup, but you'd want to trim off about 3/4" off the bottom since it curves in to fit behind the stock door panel. I've got a couple kicking around my room, I'll see if I can get you guys some pics
Old Nov 6, 2009 | 08:37 AM
HCR13's Avatar
Car: 1987 Trans Am
yeah, I had to cut alot of these off. They had small lips and brackets and I cut all of it off until it was the triangle itself left...
Old Nov 8, 2009 | 12:17 PM
CanadianCamaro's Avatar
Car: 1992 Camaro RS
Engine: 5.7 V8 TPI
Transmission: T-5 5-Speed Manual
Both the G6 and Vibe have tweeters in these locations. I'm sure they'd fit in the Third Gen with little modifications
Old Jan 4, 2018 | 12:17 PM
austin_1138's Avatar
Long dead thread, but I found that tweeter pods from a 03-07 Tiburon fit the door triangle well and don't hang past the end. They come in black so blend in almost stock like.
Old Jan 7, 2018 | 08:20 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Have any pictures?
Old Jan 8, 2018 | 03:32 PM
Have any pictures?
Don't have one in the car yet. Did a test fit with the door shut to see if it would clear the dash. If one cuts the tabs on it flush with the pod edges and applies some epoxy it should anchor to the triangle. Either that mount it to the door without the panel on with a thin piece of metal. the pod has an hallowed spot on it's bottom to allow this. Haven't tried since I wish to replace the door felts and triangles in the coming month.
Old Jan 9, 2018 | 02:28 PM
Showing how the tabs stick out cut em.
Just sitting there tabs cut. I think it looks pretty good from where I sit.
Just clears the dash.
1Aauto
Sponsored Vendors
Oct 19, 2016 08:50 AM
Fireslash
Apr 11, 2016 06:43 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
