WIRING HARNESS HELP??
Old Apr 6, 2009 | 12:09 PM
ZRHeath's Avatar
Hey guys.
When i hooked my Sony Xplod head unit into my car last year, the power supply for the radio was no where to be found, so i just hooked it right into the fuse box. After having to fix my gauges i realized that the genius that hooeked them up, hooked them into the sterio power supply. I fixed that and now have all of the wires open for the sterio and want to hook it up right. Problem is that i dont remember what the hell goes where, and for some stupid reason i didnt get a smart harness. I still have the factory harness that was on the car that we cut off. Would it be easier to figure out which wires connect to which, or to rehook up the factor harness, matching the colors and then just get a smart harness?
Also, since ill prolly atleast try to just match wires, can i get a chart or something that shows which colors are what? A chart for a sony explod head unit would be great too if anyone has it! Thanks.
BTW: 1992 Camaro RS
Old Apr 6, 2009 | 02:46 PM
88TransAmFreak's Avatar
Car: 1971 Camaro
Re: WIRING HARNESS HELP??
This from a 88, your 92 should be the same colors.
Old Apr 8, 2009 | 05:14 PM
vipergraphics's Avatar
Car: 91 RS
Engine: Soon to be 3.8 GN motor
Power for 99% of head units is
Black=Ground
Red=Switched 12v
Yellow=Constant 12v
Blue=amp turn on or power annt
Old Apr 10, 2009 | 07:09 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
88Trans, you were close, but they changed the wiring harness in 89
the one he needs is this:
Old Apr 12, 2009 | 09:33 PM
Curtisyz54's Avatar
Car: 84 z28, 86 irocz
Engine: LS6, 305 TPI
Transmission: TH350, T56
Axle/Gears: 3.73, 4.10
I was about to say that, But I thought they changed them in 90?
Old Apr 13, 2009 | 06:43 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
The one I posted is exactly what I had in my 89 RS and my current 97 Grand Prix. Made the deck swap pretty quick
Old Apr 13, 2009 | 05:34 PM
Curtisyz54's Avatar
ya i have a 86 and a 89, and I know the wire harness is the same, with the white black and blue plugs, and it uses the same wireharness adapter for aftermarket headunits. idk
Old Apr 15, 2009 | 02:00 PM
IIISLACKERIII's Avatar
Car: 1986 trans am, t-tops
Engine: sbc 400
Transmission: turbo 350
Axle/Gears: idk???
hey, thanks guys u just saved me alot of time...this web site is alwsome!!!! i didnt buy the kit so im just tryin to match colors (just like the original poster)...
Old Feb 22, 2012 | 04:31 PM
92RS4US's Avatar
Car: 92 25th anniversary edition
Transmission: 700R-4
Axle/Gears: 2.73's
can anybody tell me what the "lights on" input is for? my 92 RS has a pioneer deck in it and whenever the key is turned on the parking lights come on. Also when the key is off and you turn the parking lights on the radio comes on. I found the grey wire was hooked to the yellow wire from the stereo. Any thoughts?
FYI the brown dimmer light is not hooked up at all.
Old Feb 22, 2012 | 05:34 PM
92RS4US's Avatar
Axle/Gears: 2.73's
I unhooked the grey wire and now the parking lights come on when they are supposed to. Just wondering if I just leave those grey and brown wires alone since there is no hook up to the pioneer deck for them.
Old Feb 22, 2012 | 07:45 PM
red88tagta's Avatar
Car: Restored 88 GTA
Engine: 5.0
Axle/Gears: Posi
The grey wire is for the instrument panel light circuit. ON with parking or headlights. Brown dims the display(clock/station)
Old Feb 22, 2012 | 07:51 PM
92RS4US's Avatar
Axle/Gears: 2.73's
cool thanks. I just capped off the grey wire and the brown wire from the factory harness. The radio lights up whenever its turned on and has no wire hook up for any lights. I hate it when somebody hooks up aftermarket stereos and doesn't know what they're doing.
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
stalkier
Dec 6, 2015 11:25 PM
g.l.mos
Aug 22, 2015 12:02 AM
stalkier
Aug 21, 2015 01:54 AM
