amp rack
Old May 8, 2009 | 07:40 PM
bm87ta's Avatar
Car: 87 TA
Engine: 305 tpi
Transmission: auto
amp rack
got tired of looking at all wires hanging around and moved my amps from the hump to where the spare tire was( don't need it, got ls1 calipers now). I used 3/4 particle board because I couldnt seem to find mdf for some reason. I may just look some more and rebuild it using mdf. Only concern I have is having enough space between the two. I have about 3/4" between and the backs opened to the air.
Attached Thumbnails amp rack-100_1908.jpg   amp rack-100_1905.jpg   amp rack-100_1906.jpg
Old May 10, 2009 | 11:49 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: amp rack
Looks good, although I would cover it with carpet, or at least paint it black. Also, I wouldn't worry about re-making it with MDF. The reason you want MDF for speaker boxes is because it has the same strength in all directions, making it flex evenly, and not distort the sound. For an amp rack though, it doesn't matter.
Old May 10, 2009 | 08:59 PM
bm87ta's Avatar
Car: 87 TA
Engine: 305 tpi
Transmission: auto
Re: amp rack
thanks for the reply, wasn't sure on the mdf, seemed like it would hold up better.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
