Sub Box and T-tops
Old May 19, 2009 | 02:20 PM
bminnix's Avatar
Car: 1987 Trans Am
Engine: Chevy 350 .040 over
Sub Box and T-tops
I have an 87 TA with T-tops. I was thinking about making a sub box for the open space in the trunk after my engine swap. I have the original T-Top bag that clips into the rear. Has anyone built a sub box that allows for the T-top bag to still clip in? What size subs were you able to fit? Pictures?
Thank you
Old May 19, 2009 | 02:29 PM
88TransAmFreak's Avatar
Car: 1971 Camaro
Re: Sub Box and T-tops
yes, flush mount for 10's......I remove my t-tops all the time and put them in the stock bag. 12's will have to stick up some because they are deeper.
Clips using all the stock mounts, I may take a better pic later
Old May 19, 2009 | 02:32 PM
bminnix's Avatar
Car: 1987 Trans Am
Thanks a bunch! That's exactly what i wanted to know and look at.
Old May 19, 2009 | 02:34 PM
Car: 1971 Camaro
no problem, just browse my threads and you'll see more pics and the information to the plans to build that box.
Old May 19, 2009 | 02:45 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
If you're only looking to run one sub, this is what I had done
I have long lost the plans I sketched up and this car went off to the junkyard in the sky about 2 years ago, so dimensions and cuts have long been lost. I found this setup to work pretty well, only took up a little bit of space (and it was sealed, not just a quick plate setup), and was almost completely out of sight when the top bag was in place.
Old May 20, 2009 | 04:37 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I have a very similar setup which also has a carpeted cover made from expanded metal. It allows me to use the cargo area for "cargo" and also allows me to strap down the T-Tops. The enclosure is constructed of MDF and fiberglass with a facade on top to make it all appear flush.
Old May 20, 2009 | 09:17 PM
mtwlkn122's Avatar
Car: 91 Firebird, 06 Dodge Ram 1500 SLT
Engine: 3.1L, 4.7L
Transmission: 700r4, 45RFE
Axle/Gears: 3.23 open, 3.55?
UGH thats the only thing i hate about my system! I really wish i had a good place for my t-tops. Now i just put them in the bag and then put it in the back seat. I mean there protected but i wish the back seat was "uncluddered". Heres a quick pic of my system....as you can tell it takes up ALL the room...i didnt think about the tops when i built everything....here she is....
Old May 20, 2009 | 09:38 PM
bminnix's Avatar
Car: 1987 Trans Am
Thanks guys. Ive got an amp mounted inside the little compartment on the left of the trunk. The guy I bough the car from already had the whole thing wired with alpine speakers and amp. I think I am gonna go with two 10's and hopefully a carpeted cover.
Swapping my engine this week, so the subs will come after.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 22, 2015 08:28 PM
codeysabatini
Sep 20, 2015 11:36 AM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
IROCZDAVE (88-L98)
Sep 6, 2015 06:23 AM
