Rear speaker change is a vert
Old Sep 13, 2009 | 11:14 AM
zuma's Avatar
Car: 1969 SS Camaro, or 1990 Iroc vert,
Engine: 350 and 305
Transmission: tb350 and 700r4
I have a 1990 iroc vert and the rear speakers are in need of replacement. I have a few questions; Do I need to remove the panel to get to the rear of the speaker or is there some trick out there that I'm not seeing? Is it a pain in the butt to remove? Is there a direct replacement out there aftermarket? What size are they? I would like to reuse the orginal covers, and use 6X9, is that possible? Thank you in advance...Mike
Old Sep 13, 2009 | 12:36 PM
THEBEAST84's Avatar
Car: 84 z28 h.o./ 92 rs
Engine: 305 h/o /3.1 v6
Transmission: hybird turbo 350/t5 bog warner
Axle/Gears: non posi 3.73 / ls 3.42
Re: Rear speaker change is a vert
hey there i used 6x9 in my 92 and my 84 but iam sure there all the same !
to get the cover off you have too unscrew the hook at the top of the spaerker cover
it a really long star head screw.
then lift up on the panel it should come right off homie ! good luck !
just do eveything in reverse to put it back together !
Old Sep 15, 2009 | 07:14 PM
zuma's Avatar
Engine: 350 and 305
Thanks Beast!
Old Sep 16, 2009 | 10:00 PM
Mudskunk's Avatar
Car: 1989 Formula 350 / 2001 TA WS6
Engine: 350 / LS1
Transmission: Auto / Auto
my 89 formula 350 had one rear speaker blow i replaced both rear with:
Alpine SPR-69C 6"x9" 2-way Car Speakers
they are direct replacements and fit the bracket that are in my sail panels. they sound like typical 6x9 so dont expect a huge improvement. they are better than stock but not astoundingly so.
Old Sep 17, 2009 | 03:43 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Transmission: T5 Manual
I thought Verts had 5x7's stock in the rear? Would love to put 6x9's in there, what do we need to mod if anything? How deep can we go?
Old Sep 17, 2009 | 08:11 AM
my82roc's Avatar
Car: 89 Iroc Convertible
Verts do not have 6x9 speakers in the rear
Old Sep 18, 2009 | 06:29 AM
THEBEAST84's Avatar
yeah did see the whole vert part sorry zuma ! well the speaker cover should come out really easy ! good luck with those !
customblackbird
Aug 15, 2021 10:16 PM
Reddeath210
Oct 6, 2015 08:20 AM
kyleb24
Aug 15, 2015 08:24 AM
89lsc
Aug 14, 2015 04:58 PM
