OEM cassette w/Eclipse spkrs = pop & crackle
Old Sep 15, 2009 | 12:07 PM
tarheel's Avatar
Car: Sold: 1986 Z28 Black/Silver
Engine: LG4
Transmission: 5 spd
I have a 1986 factory cassette w/ EQ and one cassette without EQ.
I wired four Eclipse speakers to factory wiring and started having problems.
first, the sound wasn't very good. Speakers don't sound blown but sounded bass heavy.....and there is a pop sound when i turned the headunit off.
Then a few weeks later, the poping sound is now when i turn off and on the headunit and there is crackling sound through all four speakers.
I connected the other headunit and it was worse...even crackled when adjusting the volume.
I removed the rear speakers....and crackling from the front speakers...switched them and crackling from the rears.
I moved the ground to under the pass. seat, but no help.
I want to keep the factory look radio, but need some help.
Old Sep 15, 2009 | 02:16 PM
87 WHITE GTA's Avatar
Car: 1987 Trans am (SOLD), 1986 Trans Am
Axle/Gears: Stock
Re: OEM cassette w/Eclipse spkrs = pop & crackle
How many watts rms ur speakers put out? u might be underpowering them.
Old Sep 15, 2009 | 04:23 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
you could be underpowering them or they could be wired backwords (negative on positive)...
Old Sep 16, 2009 | 06:41 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
probably broken solder joints in the radios-this is a very
common problem with thirdgen era delco radios and is
easy to fix if you are handy with soldering and electronic
repair.
If problem only happens at higher volume,speakers
might be too low impedance,causing radio's amps to
distort.
Linson
Oct 24, 2025 02:00 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
