Do I really need an amp?
Old Oct 4, 2009 | 08:24 PM
84olmpcboy's Avatar
Car: 84 olympic edition camaro
Engine: 2.8
So heres my setup. I have eclipse 4x6 2way speakers up front and 2way 6x9 pioneers in the back, I also got a 96 sunfire head unit with the 7band equalizer. Now before I get bashed on here about my setup it was dirt cheap $100 for speakers, $15 for a cd radio and I just bought a $5 amp. The amp is a 300watt jensen and I was just wondering if I would be able to hear a difference if I hooked it up. Thanks
Old Oct 4, 2009 | 09:30 PM
87 WHITE GTA's Avatar
Car: 1987 Trans am (SOLD), 1986 Trans Am
Axle/Gears: Stock
Re: Do I really need an amp?
Depending on the wattage of ur speakers..but yes...as a general rule you should experience better audio with an external amp.
Say for example you have a 50 watt speaker running off 15-18 watts of each headunit channel (thats in average the wattage they put out regardless of whats advertised)
The speaker wont be running at its full potential.
If u in the other hand have lets say a 200w amp for example (50x4) the speaker will be much more efficient , the sound will be more accurate since the speaker would be running at the watts it was designed to run at.
BTW it wont harm the speaker if the amp wattage is higher than the one of the speaker,it will help it in case of a sudden need of power...
hope that helped
Old Oct 4, 2009 | 09:35 PM
84olmpcboy's Avatar
Engine: 2.8
That really helped explain what I was looking for thanks
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
