Parallel and series wiring?
Old Oct 13, 2009 | 04:46 PM
Me of Course's Avatar
Car: 1985 Iroc Z
Hey I've been doing research on parallel and series wiring and I got the basic of it. Parallel reduces ohms, which increas power output. Series increase the ohms which reduces the power output. Of course you can't reduce the ohms much without a high performance amp. Now I want to understand it a little better. If I have speakers with different watt ratings and want to give more power to a pair of speakers, let's say, and less power to another pair, could I set one pair up in series and one in parallel? I'll put up a picture because I can't explain that well in words. This is just an example. The amp is a two channel amp. If I wire it like this, will speakers A and B recieve 25 watts each and speakers C and D will recieve 100 each, or am I completely wrong?
Old Oct 15, 2009 | 04:11 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Parallel and series wiring?
it all depends on how the amp is setup. on mono and most 2-ch amps, I wouldn't do this. stereo circuits often share a lot of parts and don't take well to one channel being run much hotter than the other. Now if you were using a 4-ch amp and bridging 2 channels for each of these setups, I'd say go for it, as you'll most likely have 2 sets of amplifiers in one chassis working in dependent of each other.
Old Oct 15, 2009 | 05:09 PM
Car: 1985 Iroc Z
Oh okay I see. So is there any way to limit the power output to each speaker? Because if I have a two pairs of speakers with different rms watts how can I hook them up to the same amp without blowing them?
Old Oct 18, 2009 | 12:37 AM
327sleeper88's Avatar
Car: 1988 rs
Engine: 555BBC; Dart, Lunati, SRP, Howards
Transmission: ATI TH-400
Axle/Gears: 35 spline 9", locker, 3.00's
If your amp has an adjustable gain ****, i would hook both pairs of speakers up in parallel and set the gain way down on the lower rated speakers. also, if its a 200 watt amp, say 100 rms x 2 chan. @ 2ohms it will deliver 100 watts to each pair of speakers, so 50 watts each speaker.
Old Oct 18, 2009 | 12:53 AM
berlin305's Avatar
Car: 1987 Iroc Z 1990 RS 1991 RS
Engine: 454 soon 496
Transmission: Soon T56
Axle/Gears: 308 Posi
Also just to keep in mine it won't be true power/watts. Also keep in mind. You can blow up or amp if you bring down the ohms low. Better make sure your amp can hold low ohms or it will fry. basic ones can do 1,4,8 ohms.
Old Oct 18, 2009 | 01:03 AM
berlin305's Avatar
And on another note being as i am tired. You can lower the power but you can't not lower one speaker power to gain in another it will both get the effect of it.
Old Oct 18, 2009 | 01:07 AM
berlin305's Avatar
In that case figuring this out if it were to be true you would be pulling way over the power rating that amp can hold. it would fry.
Old Oct 18, 2009 | 02:08 AM
Car: 1985 Iroc Z
How would it fry? I mean if it was a 4 ohm amp it would, but if it was capible of holding 2 ohms it shouldn't fry, right?
Old Oct 18, 2009 | 02:15 AM
berlin305's Avatar
One thing you have to make sure what amp your using and what can it hold. 4 ohms, 8ohms and bridged? 1ohm,2hohm,4ohm? One thing when you buy an amp it will show you all these things. I know the formula's on knowing what you need and all. Basic on is Ohm's Law, Watts Law. google it very useful information on how to calculate. Also looking up parallel / series if you have any problems give me your info like volts, your amp, your ohms off your speakers and I can calculate it for you to make sure your in the safe of doing this. Mind you certain amps can't go low or high on the ohms like going 8 ohms that dosn't mean you can use 2 8 ohms to that amp its overall what you can use. Series it adds the ohm and parallel it reciprocol.
Old Oct 18, 2009 | 02:19 AM
berlin305's Avatar
Just give me your information. I need volts and your ohms of all the speakers you are wanting to use and the amp and its power rating and the ohms it could hold. I will help you out on this if you give me some info to work with.
Old Oct 18, 2009 | 11:10 AM
Car: 1985 Iroc Z
Well I didn't buy anything for my sound system. Right now I'm just trying to find out as much as I can before I actually buy it you know? But my question is, is there any way to limit how much power goes to EACH speaker?
Old Oct 18, 2009 | 03:34 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
im an electrician not an audio guy so im really taking a shot in the dark here, but is it possible to use a resistor in line with a speaker?
Old Oct 18, 2009 | 07:19 PM
Car: 1985 Iroc Z
Yeah that was like my final resort though cuz then I'd have to put resistors on every wire and like make a box to organize them. If there is no other way then yeah I'll do that
Old Oct 19, 2009 | 03:29 PM
Brennan's Avatar
put it right on the sub and hide it inside the sub box?
Old Oct 19, 2009 | 05:21 PM
Car: 1985 Iroc Z
Yeah that could be a solution. Or on the center console thing between the seats. So then all the wires from the speakers run through it. Either way it could work. Well thanks guys I guess the only thing I can do it that =]
hectre13
Dec 11, 2023 08:14 AM
Caspar
Jun 19, 2016 11:19 PM
hectre13
Aug 26, 2015 08:17 AM
Navy8125
Aug 25, 2015 08:25 PM
knight72
Aug 10, 2015 09:32 PM
