Places to purchase replacement LCD for headunit or a complete faceplate replacement?
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
Hopefully some info can be given but worth a shot.
So basically my uncle being the dumbnut he is, He ''accidentally'' dropped the faceplate of his headunit and the screen cracked and is unusable. Everything works fine and I can even navigate through CD's fine from memory where things where. So he handed over the unit since he lost hope in a fix and me being the cheap bastard I am knew a quick replacement LCD will do it.
Is there any hope for a good fix? The screen needed is a PW036XS3. I sent an email to those guys for a quote on one so I am gonna see what can be done. Any other spots to look into to check if they have em in stock?
Here is the full serial/numbers on the back of the screen if their anymore help:
PW036XS3 (LF) PWN3663001 then what seems to be the serial, 30W00NEG3502865AT. The actual headunit is a Farenheit TD-400. A fix would be great seeing as how I currently have no stereo and my music is the car sounds
If that is not possible, Anyone know a good place to look online for a replacement faceplate? Right now local swap-meets are closed since well its winter which is usually the first place I go to see if anything useable is there.
Terrell351
Jun 13, 2021 01:13 PM
