newbie needs help with rear speaker install
Old Feb 13, 2010 | 03:57 PM
3-Ball's Avatar
Car: 1984 Z28
Transmission: auto
I have an '84 z28. I had a blown speaker. I have never replaced speakers or the like. I was able to get the rear speakers out - just unclipped them - pretty easy. Now though, the replacement speakers obviously do not have the same harness so no clip. How do I connect the wiring on the new speakers? The wiring that is left in the car has one brown wire and one yellow wire that feed into the harness. I feel like an idiot asking for help on what to most is probably an easy thing to do - but I am stuck Any help would be appreciated. Thank you.
Old Feb 13, 2010 | 06:27 PM
mtwlkn122's Avatar
Car: 91 Firebird, 06 Dodge Ram 1500 SLT
Engine: 3.1L, 4.7L
Transmission: 700r4, 45RFE
Axle/Gears: 3.23 open, 3.55?
Re: newbie needs help with rear speaker install
Well you can either go two different directions with this. If you new speakers have wires coming off them you can attach the stock factory harness from the broken speakers onto the new speakers.
Or you can just wire the new speakers into the wiring in the car. Just cut off the harness and wire it straight together. Make sure you dont just twist the connections and leave them in the car. Ive seen people do that before and ummm ya...you get the point.
I did my speakers so long ago that I forgot which wire is which. Someone will chime in with which wire needs to go to which wire. I think the brown is negative and the yellow is positive. Im not totally sure on that tho.
Old Feb 14, 2010 | 05:48 PM
3-Ball's Avatar
Car: 1984 Z28
Transmission: auto
Thanks for the help! I soldered the wires connected to the new speaker to the old wiring harness I took off the older speaker and then just clipped it back in. The brown wire is positive and yellow is negative. Thanks again for your help.
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
89lsc
Aug 14, 2015 04:58 PM
