Depth of subs
Old Mar 30, 2010 | 09:30 PM
lbarile1991's Avatar
Depth of subs
Currently I am running this set up:
2 MB Quart 800W 10 Inch Subs
1 Autotek 1500W amp
2 Farad Power Acoustik Capacitor
1 600W Power Acoustik Amp pushing 2 6x9s
One of my subs decided to break around the magnet. I am thinking aboout replacing both subs. I am unsure on how deep i can go with a sub. I have been looking at these.
http://signature.crutchfield.com/s_5...3&tp=111&avf=N
Any idea if these would fit in to a normal camaro/firebird subwoofer box? And if they did, would they blow the box to pieces?
Old Apr 4, 2010 | 06:02 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: Depth of subs
You would need to measure the depth of your box and compare it to the specs of the sub. Also how much air is the sub getting now. The alpine specs are 0.5-0,8 cu.ft sealed.
The sub you're looking at is a dual 4 ohm. Which would result in a 1 ohm load if you buy two. Is your sub amp 1 ohm stable?
Lastly, ditch the capacitor...waste of money. If your lights dim...start with the BIG 3 upgrade and go from there.
InfernalVortex
Apr 20, 2021 11:31 AM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
91 SrS
Oct 7, 2015 04:32 PM
meeklay812
Oct 1, 2015 03:46 PM
