is it worth it
Old May 16, 2010 | 06:17 PM
katy91's Avatar
Car: 91 camaro rs
Engine: 5.0 v8
is it worth it
my friend gave me 2 12 in subs and an amp, i have a 91 cam. w/ t tops..... so first of all im gonna need to build a custom box and 2nd will they interfere with the t top case in the trunk? i dont really know where to start with this one, can someone point me in the right direction or give me any ideas u have. i also thought about selling the subs and buying smaller, but i dont know if that is necessary. thanks.
Old May 16, 2010 | 06:27 PM
XxFormula87xX's Avatar
Car: 1987 Formula 350
Engine: 5.7 350 tpi
Axle/Gears: posi
Re: is it worth it
well i think you will be very happy with 2 12s if you like to crank up the tunes. I have 2 12s in my T-top formula as do many others with t-tops. there is a sticky on building boxes under car audio that are great, however if you don't want to build one you can buy a box for like $200 or less. Sonicelectronix.com has a box i think shipped its about $150 to me might be more/less for you. If you build it so it sits flush with the top of the trunk space you should be fine.
here's a link to the sonicelectronix box
http://www.sonicelectronix.com/item_...+Trans-Am.html
Old May 16, 2010 | 07:14 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: is it worth it
I use 2 10s in the well area and it shakes the f**k out of my car. I can still put my tops in the stock location.
Ive got a couple of pics here
Old May 16, 2010 | 08:00 PM
katy91's Avatar
Car: 91 camaro rs
Engine: 5.0 v8
Re: is it worth it
cool thanks i checked it out thanks
Old Jul 30, 2010 | 09:49 PM
katy91's Avatar
Car: 91 camaro rs
Engine: 5.0 v8
Re: is it worth it
so.... first of all i bought a great box at the swap meet for 65 bucks, (if your in the so cal area and need a place to get sterio equipment ill refer you to the guy)... so that wasnt a problem, i got them installed at a different place tho.. the only thing im trying to fix now is it seems like the speakers by the back seats raddle like crazy !!!! i knew my lisence plate would raddle so i improvised and put some cushion between the plate holder and the actual plate, that worked, i was thinking of doing the same between the actual speakers in the back and the metal part of my car but theres no way i can get in there with out taking the speakers out which i dont wanna do alone, does anyone else have this problem?
Old Jul 30, 2010 | 10:53 PM
tkcaraudio's Avatar
Car: 65 Nova Wagon
Engine: 358
Transmission: 350 turbo
Axle/Gears: 410
Re: is it worth it
yup i have that problem i used some sray foam after i replaced my 6x9 to aftermarket
Old Jul 31, 2010 | 02:14 PM
katy91's Avatar
Car: 91 camaro rs
Engine: 5.0 v8
Re: is it worth it
yeah maybe a yr ago i got new 6x9's...... too bad i didnt get the subs first and notice it before hand its annoyingggggg
Old Jul 31, 2010 | 10:15 PM
TheMonster's Avatar
Car: 1983 Z28
Engine: Forged 355
Re: is it worth it
Yeah definetely worth it. Also FWIW, I don't have a "sub box", I just have the trunk lid with two 12" subs in them and it does the job.
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
skinny z
Oct 5, 2015 06:23 PM
bjpotter
Oct 4, 2015 07:48 PM
gord327
Oct 3, 2015 01:25 PM
6998poncho
Sep 25, 2015 02:56 PM
