sub enclosure feedback?
Old Jun 9, 2010 | 03:20 PM
j3rry92's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8L V-6
Axle/Gears: stock
im sure im not the first one to ask this but has anyone tried this sub box from subthump.com? if so, how is it? is it worth the price? do the subs sound good? does the enclosure fit flush in the hatch? any feedback/pictures or other information would be greatly appreciated thanks
http://subthump.com/Pontiac-Sub-Boxe...Enclosure.html
Old Jun 10, 2010 | 09:01 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: sub enclosure feedback?
that looks to be a very good price for the amount of work it takes to make a box for one of these cars. if it is in fact MDF, that's not bad. sound will all come down to what your specfic subs require for air space, so you'll want to make sure your subs' specs fall within what the box has for room
Old Jun 10, 2010 | 12:11 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Doesn't look to bad. Like stated make sure your subs fit the mounting depth and volume. I don't know what fasteners they use but I recommend tee-nuts be installed else the MDF will breakdown overtime from removing and installing the subs. I'd also recommend checking to make sure all the joints are properly sealed.
I figured they would be horrible on shipping but it was only $21.68 for a 49 pound box from IN to IL. Looks like the box would fit flush, but you could call to confirm.
Old Dec 12, 2010 | 07:24 PM
aqualordx93's Avatar
Car: 1986 Camaro Iroc Z
Engine: V8 305 TPI
i was looking to get this subbox for 2 12' kickers. did you end up buying it? if so how is it so far.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
camaroracer21
Oct 6, 2015 03:23 PM
Scorched1984
Sep 15, 2015 03:42 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
