door rattles!
Subscribe
Oct 24, 2010 | 06:55 PM
When ever i have my door closed and my subs going i have something in my driverside door that rattles like no tomorrow!!, i have already pulled the panel off and looked but to no avail i have found nothing, anyone have a clue? it sounds like something metal but i cant find it!!
Reply 0
Oct 24, 2010 | 08:07 PM
Re: door rattles!
check the window... with it all the way up see how much it shakes. and dont bust a back window with your subs. its no fun
Reply 0
Oct 24, 2010 | 08:19 PM
Re: door rattles!
windows were up, i thought it was my mirror but it wasnt its something internal....and i didnt think you could bust the glass with just subs?
Reply 0
Oct 24, 2010 | 09:46 PM
Re: door rattles!
Oh, You can break the back window with subs... I would check the rods that lock and unlock the doors. Also the rod going from the handle to the latch.
Reply 0
Oct 24, 2010 | 09:51 PM
Re: door rattles!
Hey Evilemokid94 check your outer door handles... if they are anything like the ones on my car they rattle and shake like crazy. I'm in the process of searching the threads here to see how to fix it.
Reply 0
Oct 24, 2010 | 10:11 PM
Re: door rattles!
Quote: Oh, You can break the back window with subs... I would check the rods that lock and unlock the doors. Also the rod going from the handle to the latch.
Anyone got a video of this?
Reply 0
Oct 25, 2010 | 05:20 AM
Re: door rattles!
check the door handle, and that little vent thats right by the lock stud on the b or c pillar
Reply 0
Oct 25, 2010 | 09:20 AM
Re: door rattles!
haha well i had a 2600 watt amp and yea... it wasnt even half way up, and the first big bass boom i was off to the junk yard.
Reply 0
Oct 25, 2010 | 09:28 AM
Re: door rattles!
https://www.thirdgen.org/forums/body...servation.html
JamesC
Reply 0
Oct 25, 2010 | 10:44 AM
Re: door rattles!
Now I'm not saying that you can't break the hatch with subs, but it's pretty damn hard. I don't think the average persons amp and sub setup is powerful enough to break the glass considering are cars are nowhere near air tight therefore it takes alot to build up enough pressure to bust that window.
However with a beastly amp and big enough subs you can break just about anything
Back to the original Q, i vote for the vents in the door jamb. Both my Camaro and Firebird had that problem and it was the vents
Reply 0
Oct 25, 2010 | 11:13 AM
Re: door rattles!
unless you actually throw the sub through the glass itself, you're not going to break it anytime soon. the air pressure can't build up enough to cause issues; you'll see the door glass push out from the roof line long beforehand to vent the pressure.
as everyone else mentioned, check the vents at the back of the door, make sure your weatherstripping's in good shape, and check to make sure the rods in the door aren't touching anything else (you can always but a little foam around them to eliminate the metal on metal)
Reply 0
Oct 25, 2010 | 02:52 PM
Re: door rattles!
Quote: unless you actually throw the sub through the glass itself, you're not going to break it anytime soon. the air pressure can't build up enough to cause issues; you'll see the door glass push out from the roof line long beforehand to vent the pressure.
Happened to me back in '93 during an IASCA regional event. Most expensive 1st place trophy I own Glass was probably defective but the crowd loved it!!
1000 watts into two 12" SS Velvet Hammers......
Reply 0
Oct 25, 2010 | 05:08 PM
Re: door rattles!
the fact that 2 ppl have done it says that the vibrations alone can crack glass... riddle me that
Reply 0
Nov 7, 2010 | 02:38 PM
Re: door rattles!
Quote: the fact that 2 ppl have done it says that the vibrations alone can crack glass... riddle me that
Sound reflexs off glass,it does not absorb it.The only way a window could break is if its already cracked .Ive seen windshields pushed out the car then breaking.
And to the OP.Check the door lock rods and door handle rods.They rattle like crazy.Put some foam used for copper pipes over them.It black and covers it completely that should fix it.Also check out the window as mentioned above.
Reply 0
Nov 7, 2010 | 05:08 PM
Re: door rattles!
Quote: Sound reflexs off glass,it does not absorb it.The only way a window could break is if its already cracked .Ive seen windshields pushed out the car then breaking.
Hmm...where can you get this stuff? I have annoying squeaks in my doors.
Reply 0
Nov 7, 2010 | 11:40 PM
Re: door rattles!
Just go to home depot or lowes and tell them you need pipe insulation. That stuff's cheap too, like 50 cents a foot.
Reply 0
Nov 21, 2010 | 09:14 PM
Re: door rattles!
update well today i took the upper black trim off of the door to see if i could see what was rattling and i still cant but when im on the outside of my car i can still hear a rattle really bad and its not my door vents or my door handle or mirror, also my 6x9 is vibrating pretty bad... but i noticed that if i applie pressure on the outside of the door about middle ways of the door the rattle stops, anyone know what it might be now? this rattle makes my car sound and looks worse than it does now and i dont like it, also i have an idea, i might take some old pillow stuffing and stuff the door to see if that till get rid of it, anyone see a problem with this?
Reply 0
Nov 21, 2010 | 09:17 PM
Re: door rattles!
how would you test to see if its the vent? i applied pressure to that aswell to see if it moved and it doesnt?
Reply 0
Nov 21, 2010 | 09:23 PM
Re: door rattles!
Fire hazard possibly i would remove the panel and then try and replicate the rattle soon enough you will have that little bast$%^ pinpointed. My subs just move the whole hatch up and down the glass is very strong and i have tint so if it does breaks it wont shatter. It could be your window motor the lock rods or the door panel hitting door skin maybe.
Reply 0
Nov 21, 2010 | 09:32 PM
Re: door rattles!
i have manual windows
Reply 0
Nov 22, 2010 | 12:01 AM
Re: door rattles!
see if you door has a inner support that goes along the door skin.
in my pickup the body shop did not glue the skin to the side impact protection, every time I shut the door or music made it rattle like a beer can with rocks in it.
check out this sight. this is similar.
http://www.ls1tech.com/forums/drag-r...al-thread.html
Reply 0
Nov 22, 2010 | 06:15 AM
Re: door rattles!
Have you read the info in the link I posted earlier?
JamesC
Reply 0
Nov 27, 2010 | 01:48 AM
Re: door rattles!
Quote: Have you read the info in the link I posted earlier?
JamesC
did you read my post?
I'm talking about the door skin not being attached. in your posts you talk about all the typical issues with 3rd gens, good posts and well detailed.
Reply 0
Nov 27, 2010 | 06:20 AM
Re: door rattles!
Though unclear, my comments were directed to the OP.
Good luck all.
JamesC
Reply 0
Nov 27, 2010 | 06:47 AM
Re: door rattles!
evilemokiid94---
Since the general agreement is something between the door & inner panel, & the panel has to be carefully removed,
while it's off, turn on the tunes & look // listen for the vibration.
If it's gone with the panel off, check the mounting tabs also.
Reply 0
Mar 11, 2011 | 10:15 PM
Re: door rattles!
got the biggest of the rattles solved, my driver side window sweep was GONE and i didnt think about that letting my window move. i got new ones and replaced both and now i have almost no rattles besides my license plate...any fix for that???
Reply 0
Mar 12, 2011 | 04:26 AM
Re: door rattles!
Quote: got the biggest of the rattles solved, my driver side window sweep was GONE and i didnt think about that letting my window move. i got new ones and replaced both and now i have almost no rattles besides my license plate...any fix for that???
Cut and put some Dynamat on the back of the license plate. Works great.
Reply 0
Mar 12, 2011 | 06:27 AM
Re: door rattles!
Is the bottom of the plate inserted in the retainer? A pic of the retainer can can be seen in post #11 (BlueeZee's car) of the following link:
https://www.thirdgen.org/forums/auto...best-rear.html
JamesC
Reply 0
Mar 12, 2011 | 08:29 AM
Re: door rattles!
Quote: Is the bottom of the plate inserted in the retainer? A pic of the retainer can can be seen in post #11 (BlueeZee's car) of the following link:
JamesC
yes it is, its more of the sides of the plate that shake and rattle, if i apply force to the entire plate and i mean a good amount of force or i hold down the sides of the plate it doesnt do it, any way i can bolt down all 4 bolt holes? that would fix rhat i believe
Reply 0
Mar 12, 2011 | 02:22 PM
Re: door rattles!
I know on my car the door panel rattles at the rear section of the drivers side door. One of the little push in clip things don't work so the top plastic just rattles on the metal every time I hit a bump.
Reply 0
Mar 12, 2011 | 02:30 PM
Re: door rattles!
I mean personally I'd just use some type of adhesive pad. Cheap, can't see it and it won't fall out. I don't know exactly how bad it is or how the camaros are set up since its been a good while since I've been around a third gen camaro but it's just a suggestion.
Reply 0
Mar 12, 2011 | 08:56 PM
Re: door rattles!
would that work though??
Reply 0
Mar 12, 2011 | 08:58 PM
Re: door rattles!
You tell me...
Reply 0
Mar 12, 2011 | 09:03 PM
Re: door rattles!
well before i do that i wanna see if there is a way for me to bolt down those other 2 bolts because that would eleminate my problem
Reply 0
Mar 12, 2011 | 09:56 PM
Re: door rattles!
I doubt if that would fully fix it since you will still have metal on metal contact. I use a small dish washing sponge behind the license plate. Has worked well for the last 8 years.
Reply 0
Subscribe
