looking to install head unit
Old Nov 16, 2010 | 03:44 AM
GREEK BANDIT's Avatar
Car: camaro iroc-z
Engine: 5.0
so i just got a 87 camaro iroc but its still got the hurting stock system.... so im looking to intstall a new head until but i don't really know how. on my firebird i had a buddy install the deck for me and we didnt have a wiring harness so he just hard wired the whole system up and i really don't know how to do that. i heard its wicked easy with a wiring harness but i don't really understand how they work. if someone could just decribe the easiest way to install one that would be great. sorry if this has already been posted but im pretty dumb obviously so bare with me
Old Nov 16, 2010 | 06:51 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: looking to install head unit
easiest way involves a wiring adapter and a mounting kit
mounting kit allows a standard, single-DIN size radio to fit the gm DIN+1/2 opening.
wiring adapter has a plug that snaps into place with your factory wiring and bare wires on the other end. these bare wires are soldered/heat shrinked or crimped (do NOT just twist and tape. bad bad bad for a car environment) to the bare ends of the new radio's harness.
all wires are color coded and the instruction manuals with both the radio and wiring adapter will have a pin out of their harness connections.
Old Nov 16, 2010 | 08:38 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The best part about the adapter harness, besides the fact that it keeps your car intact, is that it lets you do all of your connections on a work bench instead of buried inside of a hole in the dash board.
Here's a write-up that I did a few years ago (scratch that... over 10 years ago now!!) that might help:
https://www.thirdgen.org/stereo2
Old Nov 16, 2010 | 01:48 PM
Car: camaro iroc-z
Engine: 5.0
thanks for the help guys it should be pretty easy once i get the right stuff.
Old Nov 16, 2010 | 08:35 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
You're one of the lucky ones to have the car's wiring harness intact. To install a stock deck in my 89, I had to get the harness for the radio and connect that to the cut harness in the radio hole
Old Nov 16, 2010 | 09:54 PM
quickkris2006's Avatar
Car: 1991 camaro vert
Engine: ls1 soon
Transmission: t56 soon
Axle/Gears: moser 12bolt 4.10 soon!
yep u can get the wiring harness connection and adaptor plate from good old walmart both for under 30$ total.. should only take maybe 30 min to install just match the wire colors together and plug it in
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
hectre13
Aug 26, 2015 08:17 AM
NinjaNife
Aug 23, 2015 11:49 AM
ZsTransAm
Aug 11, 2015 07:30 PM
