I'm sure some one has done this BUT
Car: 1988 Firebird Formula 350
Engine: L98 383 cubes Multipoint FI
Axle/Gears: Ford 9 inch with 3.70 gears
I'm sure some one has done this but my
are not coming up with anything on this website or web.
What i'd like to do is put an 8" sub in the compartment on the drivers side in the trunk. I'd like to buy or make one. If some one has measurements for a box there i'd like to have them to avoid making a mistake and having to make the box twice.
Thanks you to anyone that can point me in the right direction.
are not coming up with anything on this website or web.What i'd like to do is put an 8" sub in the compartment on the drivers side in the trunk. I'd like to buy or make one. If some one has measurements for a box there i'd like to have them to avoid making a mistake and having to make the box twice.
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: I'm sure some one has done this BUT
you dont really make a box for that, all hasse is working on that now hes using 2 excelon kenwood 8's, you seal off the compartment and use a board to mount on the front of it, youre pretty much making your dead space into the box, hit him up he should be able to shine some light on the subject, i just cut his panels for him
heres his thread https://www.thirdgen.org/forums/car-...tem-under.html
