Alpine Type R VS Kicker CVX?
Old Nov 29, 2010 | 05:50 PM
timatom's Avatar
ok, so i got 2 kicker cvr at the moment and i really like them. unfortunately i didnt break them in like a normal human being i decided to turn the amp all the way up and blew them!. so im going to replace them this weekend. i was wondering if anyone had had the type r and if they like it better than the cvr? and should i get the cvx or the type r?
i listen to rap/hip hop mostly, would it be smart to go with one 15 instead of 2 12's... im looking for alot of low base?
for the money i can get,
2 cvr 12": $140
2 cvx 12" $250
2type r 12" $200
i dont know about 15" i didnt price them?
Old Nov 29, 2010 | 08:32 PM
wiweeds's Avatar
Car: 1991 RS
Engine: 350tbi
Re: Alpine Type R VS Kicker CVX?
Go to Fi car audio.com You can buy a sub there in your price range and it will be much better than any kicker or alpine. A 15" isnt a bad idea if you're really attached to low bass but to me 2 12" should do fine while still getting higher notes good. For instance thought the Fi SSD is one of their lower lines ($179 for a 12) and it is said to beat the kicker L7 also the subs are made to order
Old Nov 29, 2010 | 09:21 PM
dspencer24's Avatar
Car: 91 z28
Engine: 350/ported accel tpi/AFR 195
Transmission: t-5 =(
Axle/Gears: 345
not many people know about fi they are a great sub. You can also look into getting a single 12 and porting it to a lower FQ. IF it was me out of those 2 subs I would get the type r and port them. I have heard both subs in 10's and 12's to my ear the type R's sound cleaner and louder at higher volumes. Its all in the install though.
Old Nov 29, 2010 | 09:25 PM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
The hatchback will help with the bass. might look into re audio sex12d4 http://www.sonicelectronix.com/cat_m...ubwoofers.html
I would get more a sql/sq sub that sounds good at high volumes with out distorting as the hatchback can make alot of bass sound sloppy.
Old Nov 29, 2010 | 09:34 PM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
2 cvr 12": $140
2 cvx 12" $250
2type r 12" $200
As far as you blowing the subs what amp are you using? Between those 2 subs you picked compaired to your cvr. there is a a big wattage difference
Old Nov 30, 2010 | 02:41 PM
timatom's Avatar
im running a 2000watt fusion amp, one of my kickers is totally gone i tested it in school with my teachers multimeter and he told me it was dead... but i dont know, i have the subs brigged....
Old Nov 30, 2010 | 03:01 PM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
Do You mean you have them wired in parallel or you do have your amp bridged? what subs are you runining actual model number? If only sub is blown You could always just get one CVR and save some money and turn your gain down and your bass down on your amp
Old Nov 30, 2010 | 09:01 PM
timatom's Avatar
i got the amp brigged, but i want to get a new set because the other sub sorta "pings" when the bass is real high.. it never use to do it but thats wht the one that blew did before it did.
Old Nov 30, 2010 | 10:49 PM
supr_fly03's Avatar
Car: 83 Z28
Engine: F-body LT1 swap
Transmission: T-56 swap
Axle/Gears: 10 bolt w/ 28 spl posi, 4.10, disks
I have a 12" type R in a custom sealed box being pushed by a V12 Mono amp. Most people cannot believe it is only one sub cause it rocks. Super clear at high volume in any car I have had it in. I have had a lot of different subs over the years and this one has been the cleanest. Put it in a ported box and get ready. I vote a type R.
Old Dec 1, 2010 | 09:15 AM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
yes i agree i had 2 type'r 10's in a custom ported box tuned a little higher for sql and i got so many compliments on that. set up. After that i went to a one sub set up for space and weight and, i will never go back to 2 subs.
Old Dec 4, 2010 | 03:19 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Fi SSD 12" or 15" ported for deep bass
https://ssl.perfora.net/www.ficaraud...iew.shopscript
Old Dec 4, 2010 | 03:30 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
The CVX is an amazing sub... I have a friend with 2 type r's. They are nice, but I am kicker all the way, I had 2 CVR's but I sold them and am looking to go with one CVX in the future.
Old Dec 12, 2010 | 01:54 PM
dredre08's Avatar
Car: 1986 Trans Am/1988 Camaro Iroc-Z
Engine: 305 TPI/350 TPI
I've owned both the type r and cvx subs let me first say they are both great subs I have the type r's in my trans am now, with my experience with them I would have to say get 2 12" cvx, when paired with the right amp they produce incredible bass and get louder then the type r's any day of the week, don't get me wrong when the type r's are matched with the right amp they sound beautiful and would even say that they are clearer then the cvx in my opinion.... it kinda depends on how you like your music if u like really deep bass and subs that get really loud go with the cvx's if you like a little better quality but still good base go with the type r's but really u wouldn't be disappointed with either one since you are upgrading for cvrs..... hope this helps
InfernalVortex
Apr 20, 2021 11:31 AM
MrPackstin
Oct 25, 2017 08:09 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
Briandrex
Oct 5, 2015 06:20 AM
bjpotter
Oct 4, 2015 07:48 PM
