NEED 92 CAMARO AUDIO HELP
Old Jan 4, 2011 | 10:32 PM
bikerboy904's Avatar
Car: 1992 Camaro RS
Engine: 3.1L V6
Transmission: 700r4 Automatic
just wanted an input on how i should set this up..... i got an 1100W amp hooked up to 2 12" KICKER Comp subs. pioneer 6"x9" in the back, and a sony xplod headunit. headunit is brand new, and pushes 52Wx4 so thats good for power. but i also got an extra 150W kicker amp that i am currently not using, and was wondering how i would go about hooking those up to my pioneer 6x9's for more clarity and volume....? how do i do it? does anyone know?
Old Jan 5, 2011 | 06:42 AM
Red 87 GTA's Avatar
Car: 87 GTA flame red
Engine: 5.7 l98 cranes 2032 and chip
Transmission: stage 10 700r4
Axle/Gears: 3.27 axle
Re: NEED 92 CAMARO AUDIO HELP
you need to conevrt your standard speaker wire to RCA if thats the input you have on the smaller amp
Old Jan 5, 2011 | 07:04 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
what does your deck have for pre-outs? guessing that you have at least one set for the sub. if you've got another set for the rears, that will be the best route to go. rca > amp, amp > speakers. you'll have to run new wires for the speakers, the amp will depend on what size you used for the other one (if its big enough, you can just use a distribution block to split the power + ground cables). remote turn on can be tied into the previous amp's
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BADNBLK
Nov 16, 2016 09:12 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
