any pics for power antenna replacement?
Car: 1988 Camaro IROC Z
Engine: 5.7L TPI
I need to replace my power antenna motor. Understand it is behind the left front tire in the fender...does anyone have a tech article or pics of what I'm in for?
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
Re: any pics for power antenna replacement?
Once you remove the plastic inner fender skirt, you will see the antenna just behind the fender. I had to replace my antenna (not power) and it was a little bit of a pain but I imagine the power is easier.
Just remove the fender skirt, and take a look. I believe there is a bracket that holds the power antenna on, and the top of it may just be attached to the fender with a nut of some sort.
Sorry, I don't have any pictures or any links to any type of technical article,s but I hope that helps.
Car: 87' IROC
Is the antenna down? Or is it stuck up?
Basically you need to remove the nut from the top outside of the fender with either a power antenna tool ($10 at Autozone) or needle nose pliers. Then there is a bracket that needs to be removed from the antenna motor. Remove the electrical connector then it will slide out of the fender.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
