Factory CD Player problems ("ON" not working at times)
Old Jun 3, 2011 | 02:31 AM
camarosource's Avatar
Car: Custom 1992 Camaro Z28 25th Anniver
Engine: 5.7L V8 350 L98 TPI
I have this type of factory radio
And I have been experiencing an issue with the radio. That has occured for years now but was completely at random. But this passed week it's done this every time I first start the car and attempt to turn on the radio.
I turn on the car and press the "POWER" button on the left and nothing happens.. No response.. Yet the other buttons like "set" work...
I basically keep pressing the power button and it just doesn't respond. Then either leave it for like a few mins and try pressing it again (then it suddenly works as if there was nothing wrong in the first place), or just keep pressing and suddenly it will work.
It's nothing to do with something loose I don't think because it just works whenever it wants to.
I've tapped the cd player and it's nothing loose.. as if the power to the switch is being blocked and then something gives way or something.. Strange..
Any ideas?
Old Jun 3, 2011 | 05:53 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Factory CD Player problems ("ON" not working at times)
Definitely sounds like a problem with the power button.
I would try removing the front cover and checking for grime inbetween the button and the circuit board. Like fixing a TV remote control.
Old Jun 3, 2011 | 01:38 PM
rdhanded2's Avatar
Top Answer: 1
Car: 91 TA / 91 Formula
Clean the contacts on the board with alcohol and a Q-Tip. Not too much because over the counter alcohol still has some water in it. If it is dirt that should do the trick.
Old Jun 3, 2011 | 01:41 PM
if it is that, how would it just work after a short while on it's own? Almost like the power needs to build up at the power button.. strange..
Old Jun 5, 2011 | 08:15 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Temperature changes can make electronics come and go.
Ghettobird52
Jul 5, 2024 11:18 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
justin57
Aug 20, 2015 07:05 PM
novaderrik
Aug 10, 2015 12:44 PM
