big 3?
Old Jun 23, 2011 | 10:28 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
big 3?
can someone walk me through the step of the big 3? i want to do it shortly.
Old Jun 25, 2011 | 12:02 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: big 3?
big 3 - alt to battery +; battery - to chassis; engine block to chassis. i recommend 4ga or bigger.
the alt you can do in addition to the factory cable and i highly recommend fusing the cable (as you should do with any + cable in a car).
make sure you have either: a. a crimper that can do 4+ ga reliably. b. terminals that have set screws that make a good solid connection
Old Jun 27, 2011 | 05:59 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: big 3?
i ran 4ga from my alternator to my battery and then 0ga for the grounds (extra lying around the shop) kinda overkill on the grounds but it works
If youre using a side post battery you should get car audio terminals for it though, makes it MUCH easier for adding accessorie/ doing this, its pretty much a battery screw with another one built into it, so one holds the cable to the battery and the second one can be pulled out of it to add the other cables, dont overload it though, i hate seeing batteries with 20 things coming off of them lol
and Dan is right, make sure youve got something that can crimp the terminals properly, you can either get a crimper that looks like a set of bolt cutters or you can get the hammer style, strip the wire place the terminal in the crimper, put the wire inside the terminal and beat it with a dead blow hammer
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
3.8TransAM
Oct 1, 2015 07:47 PM
dusterbd
Sep 29, 2015 08:40 AM
