Sound Difference? Advice
Old Aug 1, 2011 | 10:35 PM
ZWis212's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
I am getting subs tomorrow and i dont have time a make a box now as i am very busy. If i cut out a piece of wood and lay it over the well of my car and secure it and put my subs there for now how bad would they sound since they arent in a sealed box? would it still hit pretty hard? im new to this stuff so i dont really know. Just wondering if that would make do for now. Thanks.
Old Aug 1, 2011 | 10:59 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Re: Sound Difference? Advice
Probaly bounce all over the place.
Old Aug 2, 2011 | 12:05 AM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
It wouldn't be good for the sub unless it's designed for an infinite baffle (open air, no box).
Old Aug 2, 2011 | 10:18 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
you'll lose a decent amount of output because it is not sealed; the front wave and rear wave will be cancelling each other out. yes, you'll still have some sound, but not to the extent you could have.
Old Aug 2, 2011 | 02:25 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I'll play Devil's Advocate here and say it'll be fine - depending. If you're looking for earth shattering bass, it won't do it - but they'll dfinitely hit and you'll hear/feel it. I'm an old fart - no desire for earth shattering bass here - but I have a 10" Kenwood sub in my hatch on a "shelf" like you describe - the "shelf" seals pretty well, but it's by no means "air tight" - and it's on a 1000watt amp (some el cheapo brand), and it hits fine and hard (for me) and really adds to the sound of my music (older rock. 1980's rock, etc). Here's a pic - 1 sub, 1 empty cover on other side, amp mounted on underside: http://i287.photobucket.com/albums/l...2RS/hatch1.jpg
Old Aug 6, 2011 | 05:23 PM
SWTWCGTA's Avatar
It will work fine and sound good if the sub is designed for it. The thing is that a sub that works well in this installation will not work well in another type later.
Old Aug 7, 2011 | 12:02 AM
IROC#1's Avatar
Car: 1988 IROC Z
Engine: 5.7 litre
Axle/Gears: 3.27 Posi with 4 wheel disc brakes
I built a sealed box for that same shelf area and installed one 10 inch JBL sub and it hits hard. Its amazing what a sealed box will do for you.
Old Aug 7, 2011 | 10:43 AM
cdoyle's Avatar
If your subs are not made for that type of baffle, you might even end up damaging your subs.
I would just wait and get the box built before trying to hook them up like that.
Old Aug 8, 2011 | 07:00 PM
onefast85's Avatar
Car: 85 camaro
Engine: 605in bbc
Transmission: powerglide
Axle/Gears: 12bolt with 4.10's
i have always ran 2 12's on just a plate in the back,mine is hinged so i can access a nitrous bottle underneath...i am fixing to uprade to better subs but here is a current pic.and it sounds great...mine is a pretty tight fit.
Old Aug 8, 2011 | 07:53 PM
-srs-'s Avatar
Car: 1991 Z28 Vert
As a former installer...it stinks.
Old Aug 8, 2011 | 08:36 PM
onefast85's Avatar
Car: 85 camaro
Engine: 605in bbc
as an amature stereo guy who has had systems that hit over 150db, it sure sounds decent.
maybe we can compare cars sometime beings i am 20minutes from you.lets see what you got?
did you even read the 1st post?
chazman
Aug 28, 2018 03:25 PM
neekolzun
Aug 24, 2015 04:59 PM
chazman
Aug 22, 2015 02:01 PM
stalkier
Aug 21, 2015 01:54 AM
Hello, Michael
Aug 20, 2015 03:19 PM
