what alternator/battery people using
Old Aug 2, 2011 | 06:10 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
I am using two amps. One is about 200 watts and it poweres my fronts and sail panels. The other amp is 1200 watts for my sub. They are drawing way to much power so my battery volts bounce to the bass. so I need a battery alt combo that will work. Doesn't have to be all to fancy. Just needs to fit my needs
Old Aug 2, 2011 | 06:36 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: what alternator/battery people using
Have the amps grounded well? Stock battery should be plenty. Need like a 4 guage wire for the grounds on the amps, and connected well to bare body metal.
Old Aug 2, 2011 | 06:40 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Yeah. Could be bad grounds. I had a thread under electrical about my alternator wiring because even before I hooked it all up, when I am idleing volts are good, 14 or so, but as soon as I put in drive , they drop to like 8 or 9 and radio and things cut out. I may just have a bad alt and battery
Old Aug 2, 2011 | 07:00 PM
Car: 1992 RS
Engine: Carbed 350
could be - both alternator and battery can be tested at most any parts store - while still in the car.
Old Aug 2, 2011 | 09:14 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Somebody also suggested running deck straight to battery . Yea? Nea?
Old Aug 2, 2011 | 09:42 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I like my deck on a switched 12V source so it only comes on when the key is turned to run or acc. Deck memory should be on a constant 12V source.
I have a Yellow Top Optima (actually 2 and an isolator) powering my system and have had zero issues with it (them) for more than 10 years. My alternator is a stock CS130 that has been rewound to output 140 amps and has no trouble with the draw of my 1400 watt Memphis Belle. Also, all my power and ground cables are at least 4 AWG .
Old Aug 2, 2011 | 09:55 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Yeah. I may have to just get a yellowtop. I rewired my alt like I was told to on Cascade Crew site, but it didn't help. I also tried running it while jumping my battery with my truck, but also didn't help. It works till like volume three, and then just my sub works, but my front and sail speakers cut out.
Old Aug 3, 2011 | 02:46 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Well, wi just had battery and alt checked. Both are good, so I don't know what the heck is going on. Any help or ideas will be appreciated
Old Aug 4, 2011 | 01:13 PM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
230 amp alternator with two deep cell batteries and I am running a 1800watt and 1200watt amp and I have no problems.
Old Aug 4, 2011 | 01:30 PM
crash17's Avatar
Car: 92 camaro
my 2 cents.
do not run your head unit straight to the battery. it could end up killing your battery or starting a fire.
upgrade the battery, i usually find the biggest cca battery i can fit and go with that. i use the yellow duralast and have always been good to me even it a 2400 watt rms system on stock alt.
4 ga is absolute minimum i would go.
and like said before be sure all grounds and power connections are in good shape. number 1 problem in car stereo installs.
i have used capacitors to help with the pulsating lights but that should only be used as a band aid on high volume levels.
how are your amps wired? i mean is the sub amp closest to the battery then feed to your small amp?
i like this site a lot for car audio info cause they have small real handy calculators and charts. the12volt.com
Old Aug 4, 2011 | 01:34 PM
crash17's Avatar
Car: 92 camaro
it may also be a ground that is not in the stereo wiring if you have the volt drop just driving with the stereo. you can try just adding a good ground off the battery.
Old Aug 4, 2011 | 01:40 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
It ended up being the ground. I still think I need a bigger alt, but it will work for now. I was thinking a powermaster 140 should be enough for my setup
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Pac J
May 17, 2020 10:44 AM
LC2 TECH
Oct 13, 2015 11:53 PM
MadOTC
Oct 13, 2015 04:46 PM
