Where to find Delco radio plug?
Old Nov 9, 2011 | 06:37 PM
Jason444's Avatar
Car: '92 Formula, '92 TA, '91 ZR-1
Engine: 350, 305, LT-5
Hi everyone,
I am looking for a replacement pigtail so I can reinstall a factory radio in my Formula as mine was cut out for an aftermarket stereo by a prior owner. Where can I find a replacement that will be a color to color match without going to the junkyard and cutting out an old harness? I searched this forum yesterday and saw the name of a company that had them, but didn't write it down and can't find that thread today.
Thanks!
Old Nov 9, 2011 | 06:56 PM
Drew's Avatar
Re: Where to find Delco radio plug?
They shouldn't be all that hard to find... Try google...
http://www.carxtc.com/servlet/the-22...1992%2C/Detail
Old Nov 9, 2011 | 07:02 PM
Jason444's Avatar
Thanks Drew...guess I was using the wrong words in my Google search.
Old Nov 9, 2011 | 07:09 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
It looks like the one Drew linked you too would be no more than cutting one from a junkyard, since has pigtail leads & would require splicing in to. Brand new not used, but splicing still required. Although I seriously doubt you could ever find one that was 100% to wherever the wire lead terminated.
Old Nov 9, 2011 | 07:32 PM
Drew's Avatar
If a person wanted to get REALLY tricky, they could buy the terminals from the dealer, and TXL wire online, then make up a whole new radio harness... But it'd be a little silly since no one will ever see it buried in the dash.
Old Nov 9, 2011 | 09:56 PM
2rgeir's Avatar
Car: 1985 Trans Am and 1990 BMW 850i
They might want to look there if he takes it to Pebble Beach....
Old Nov 10, 2011 | 05:27 AM
Jason444's Avatar
I'm ok with just neatly splicing the pigtail into the existing harness with butt splices.
Old Nov 10, 2011 | 09:11 AM
Car: GTA
Get a soldering iron, shrink tubing & solder them together. I hate the crimp butt splices.
Old Nov 10, 2011 | 01:16 PM
hunter29078's Avatar
Okay this is a little of topic but I have an 89 rs. I don't know what radio came in it, it did not have a radio at all when I bought it. The harness was cut off, I am assuming I would need the delco one mentioned above ot this one http://www.ebay.com/itm/Buick-OEM-Ca...sories&vxp=mtr
But if am going to do an aftermaket radio what is my best option? I was thinking of putting the factory harness back on them buying an adapter with my new radio. Thinking the the factory harness would be easier to match the color wires too then getting an adapter would make it easier if I change radios down the line, no more splicing.
Old Nov 10, 2011 | 03:17 PM
Drew's Avatar
89 would have had the three separate plugs (white/blue/black) with another plug for keep alive memory. The Ebay auction you linked is an aftermarket version, or you can get the right separate plugs online too.
If you're using an aftermarket deck, I'd go one of two ways... If you're going to use the factory speaker wires, go ahead and wire in a stock plug and use an adapter. If you're going to run speaker wires anyway, run a new power and memory wire from the IGN and BAT terminals on the fuse block, wire up your speakers and go. It'd be silly to mess with harnesses and adapters for 12v+ constant and 12v+ switched.
Old Nov 10, 2011 | 03:45 PM
Thanks. I will try to find the 3 seperate plug harness.
Old Nov 10, 2011 | 03:49 PM
While looking found this also and thought it may be relevant down the line
http://www.installdr.com/Harnesses/GM-Wiring.pdf
Old Nov 10, 2011 | 09:04 PM
Drew's Avatar
Pico sells the three separate plugs... http://www.picowiring.com/pdf/Cat-35-38.pdf
So does a vendor on Amazon... http://www.amazon.com/Stereo-Harness...BK?tag=bmpj-20
I don't see the 12v constant plug though... It's the same as the speaker connectors.
Google with terms like "GM radio repair harness", it might take a little digging.
Old Nov 10, 2011 | 10:33 PM
*84TA's Avatar
Car: 84 Trans Am
88 and newer
http://www.ebay.com/itm/GM-Stereo-Wi...item5d2cd497b4
87 and older
(add says up to 91, but they are wrong. GM changed to the 20 pin plug in 88)
http://www.ebay.com/itm/GM-Factory-S...item2c539ca6aa
Old Nov 11, 2011 | 08:24 AM
88 and newer
87 and older
Thanks I looked for them last night and couldn't find them (plus I didn't know what they looked like). I searched 89 camaro radio harness. Got all kinnds of thing but not the three wire harness. Gonna get some and go ahead and install a the radio. Probably 4 new speakers to. An suggestion a a single din unit and speaker (front 4x6??;rear 6x9??) that will sound descent.
Old Dec 30, 2013 | 08:26 PM
kingzrt's Avatar
Car: 1987 IROC-Z
Engine: 5.0 305ci 4 barrel Edelbrock carb
Guys,
I have an 87 Iroc, trying to reinstall the original factory radio. I have ordered 2 pig tails already and both not the one's I need. Everything I have seen on this post doesn't come close. http://www.ebay.com/itm/Buick-OEM-STOCK-Radio-WIRE-HARNESS-PLUG-1982-1987-/110705534406?pt=Motors_Car_Truck_Parts_Accessories&hash=item19c69065c6&vxp=mtrThis one looks the closest to what I have, I do not want to order another without being sure..Fortunately they have all been $3-4 each. The link shows it is for a buick, I know GM is GM can someone just verify...thanks alot
Old Jan 1, 2014 | 01:34 PM
my82roc's Avatar
Car: 89 Iroc Convertible
You need the male pigtails.the link you posted shows the female pigtails.I believe I have a set here
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Jan 19, 2016 12:21 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
1989formula5.7l
Aug 17, 2015 02:56 PM
