swapping out antennas
Old Nov 11, 2011 | 02:24 PM
emerald91fbird's Avatar
Car: 1991 firebird
Engine: 3.1 l v6 mpi
Transmission: auto
Hey i have a 91 base fbird it has a non working power antenna i want to know what i really need to do to switch it over to a solid antenna
Old Nov 11, 2011 | 06:01 PM
Hal87's Avatar
Car: '84 Firebird TA & '87 Camaro LT
Engine: 350 V-8 & V-6
Axle/Gears: 3.23 & 3.42
Re: swapping out antennas
Not hard, took me about an hour to do mine. Pull off the right front wheel and remove the wheelwell liner. If you have a tool for the pop-in fasteners it goes faster. Take the lower passengers panel and the front panel off the dash and pull out the radio. Unplug the antenna lead and pull it back to the inside of the fender wall. Disconnect the antenna relay (under the front right dash panel). Use a screwdriver to work out the rubber weather plug. One 10 mm bolt holds the antenna mounting bracket on, remove it and take off the trim nut on top of the antenna tube. Now you can remove the antenna assembly, feeding the cables out through the hole in the fender wall. Put the fixed one back in opposite order. I disconnected the other side of the antenna relay too, so it could not be energized. Ez-Pz
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
