i-pod jack
Old Jan 22, 2012 | 05:04 PM
spotspot's Avatar
Car: 90 RS Camaro
Axle/Gears: stock
i-pod jack
can any one give me pics or a diagram on how to add an i-pod jack to my 99 chevy truck radio now in my 1990 rs camaro
Old Jan 22, 2012 | 06:18 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: i-pod jack
I have the same radio in my 89 Camaro, but a 2002 model. I opted for this piece from Precision Interface Electronics (PIE) so I could run audio from my SIRIUS receiver through my head unit by using a mini-jack-to-RCA cable.
http://www.pie.net/index.php?page=sh...mart&Itemid=40
It says not compatible with 1999 AM/FM/CD head units. You might take a look at the sticker on the head unit's housing and check manufacture date, If you have a 2000 head unit, you might be able to use this.
If you search, there are other threads on how to tap into the audio inputs on the radio's circuit board and install a mini-jack for auxiliary audio input.
Old Jan 22, 2012 | 11:33 PM
spotspot's Avatar
Car: 90 RS Camaro
Axle/Gears: stock
Re: i-pod jack
well i figured it out will post pics and instructions later
Old Jan 27, 2012 | 08:08 PM
spotspot's Avatar
Car: 90 RS Camaro
Axle/Gears: stock
Re: i-pod jack
here is everything you need to know about installing an aux jack in your stock head unit
http://www.ls1tech.com/forums/stereo...t-adapter.html
Old Feb 12, 2012 | 04:36 PM
bedbed's Avatar
Car: '82 Z28
Engine: 305 LG4
Transmission: 200c
Re: i-pod jack
Spotspot. I have this CD player mfg date '01. Would you know if this would be the same as far as first/third wires in the CD connections as what your link shows? Is a double DIN, so still have to size this up as far as fit, but there is an area in the front panel that the aux jack can go. Still using original unit in my Camaro.
Old Feb 12, 2012 | 06:12 PM
spotspot's Avatar
Car: 90 RS Camaro
Axle/Gears: stock
Re: i-pod jack
most chevy delco units are the same the wires very from year to year if you can determine what wires are sound then you can tap in to them i riged up some tools with an old ear phone bud speaker and a needle to check for sound good luck ask me if you have any ?
gta892000
Aug 11, 2019 11:16 AM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
z28joe2
Sep 28, 2015 05:54 PM
roysatikas
Sep 22, 2015 08:15 PM
John in RI
Car Audio
Sep 10, 2015 11:24 PM
