New Box, New Problem
Old Apr 24, 2012 | 04:59 PM
GreenCamaro13's Avatar
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
Axle/Gears: 5 Speed Manual
Ok so i recently got a custom box made to fit the back of my maro' problem now is that i have to lift the box up a bit so that the locking mechanism can work on the hatch. if i dont it wont shut at all, is there a way to fix this?
Old Apr 25, 2012 | 12:02 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: New Box, New Problem
if a shop made the box for you, i'd take it back and explain the issue. not sure why you'd be having that problem, but they may have to trim the box a bit for better clearance.
Old Apr 25, 2012 | 01:35 PM
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
no man, i bought it used for 30$ so they wont do that, but im sure i can make something work, probgably relocate the little engine it possible?
Old Apr 25, 2012 | 04:13 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I have a similar issue with the one I had built, but I can live with it. To remove the box, the pull-down motor has to be removed, otherwise everything works great. I look at it as theft deterrent
Old Apr 25, 2012 | 08:45 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
So the box was custom made for A Camaro, not yours. Your gonna have to cut out a piece so that it cant lean up Agianst the "hump". Mine leans on the hump so much that most of the weight is Agianst the hump. But I have no issues with my pull down motor.
Old Apr 25, 2012 | 09:00 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Sorry but Im a firm believer of modding the part before modding the car to make something work.Especially if the factory part works just fine without the box in there..why mess around with it? Tailor the box to work in your car..not the other way around.What will you do if you relocate the pull down motor and make matters worse of it either trying to pull the hatch in too tight or its up too high and doesn't seal?..keep modding the hatch..I dont think so.
Mark where the box is making contact..trim it down and recheck clearances untill all is well.Its only a $30 box right.
Street Lethal
Apr 30, 2019 12:14 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
MyRedCamaro
Dec 29, 2015 05:16 AM
backtothe80s
Sep 5, 2015 12:39 AM
overdriv
Aug 20, 2015 03:52 PM
