Power Antennae - a couple questions
Old May 10, 2012 | 08:46 PM
NowhereFast's Avatar
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
My car came with the power antennae. Mine is broken. I think it would work, being as the green wire is cut (which I believe provides power to the unit), to stop the constant spinning due to a broken strap. However, the mast is bent, and it would be easier for me to just replace the one I have.
This is what came out of the car.
Size:  118.4 KBName:  powerantennae2.jpg
Is this the factory antennae?
http://www.ebay.com/itm/170836496042...ht_1224wt_1402
I saw this on ebay, and it looks different. I realize they could have changed over the years, but I want to make sure I don't buy an incorrect one.
Also, if that one won't fit properly, does anyone know where else I can look for a direct replacement?
The part number on the mast is 22071862 and on the body (base of mast) is 22062579. I searched that and nothing came up.
Thanks in advance.
Old Aug 26, 2012 | 07:13 PM
Motorhead911's Avatar
Car: 1986 pontiac firebird gta
Engine: 350 ci
Transmission: auto 4 spd
Re: Power Antennae - a couple questions
i am having the same problem, can not find power antenna, purchased two so far, autozone and ebay, both are 5 inches too short .
return what I can. but need some help finding the right one. to fit in hole in fender, and no i do not want to cut inner fender.
as you can see in the photos the antenna hits the inner fender, original fender, If I found the right one I will post.
also could not find isolation relay so I just put jumpers on the pug ends and everything works fine so far, also circuit breakers instead of fusable link.
thanks...
Old Aug 26, 2012 | 07:14 PM
Engine: 350 ci
trying photos now
Attached Thumbnails Power Antennae - a couple questions-2012_08_20_1015cut.jpg   Power Antennae - a couple questions-2012_08_20_1073cut.jpg   Power Antennae - a couple questions-2012_08_20_1021cut.jpg
Old Aug 26, 2012 | 07:41 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Modern day has the repair kit for the original.
Old Aug 26, 2012 | 09:12 PM
Engine: 350 ci
my original is broken in a few places, but will look at what they have and maybe try junk yard parts
Old Aug 26, 2012 | 11:40 PM
Engine: LB9, LS1
Thanks a lot Manta. I found the same thing on eBay and it was $150. I'm gonna order it tomorrow.
Old Aug 27, 2012 | 08:44 AM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Just replaced mine this spring with one from thirdgenranch;http://thirdgenranch.com/-strse-984/...nna/Detail.bok I had to cut the bracket off of my old one and weld it on the new one, but it works great when replaced.
Old Aug 27, 2012 | 09:28 AM
Engine: 350 ci
do not buy from antenna_x on ebay, sounded great , but wrong antenna was sent, it is the center one in the photos,
returning it now.... but there is others on ebay , $200-280 for the correct ones. same as from the webs sites, modern day mucsle , ebay, third gen ranch , and repair place, i listed be low to help others.
was hoping for a 100 replacement, nearest I got was $172
http://www.moderndaymuscle.com/inc/sdetail/25289
http://www.ebay.com/itm/POWER-ANTENN...11%26rk%3D1%26
http://monsterautoparts.com/PONTIAC/...na_product.htm
http://www.antennamastsrus.com/GM/Po...ird%201979.htm
http://thirdgenranch.com/-strse-980/...nna/Detail.bok
http://www.ebay.com/itm/ws/eBayISAPI...ectorid=229466
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
