What size alternator?
Old May 17, 2012 | 07:18 PM
iinversion's Avatar
Car: 1987 IROC-Z (G92)
Transmission: M5
I am running a 1200 RMS amp (Hifonics Brutus BRZ1200.1) and a 300W RMS Alpine amp for the speakers(can't think of model right now)I have upgraded the big 3 with 1/0ga wires and I have 1/0ga wire running all the way back to the amps.
My alternator cannot keep up especially with other electronics on(lights, radiator fans, etc) and it really bogs down and I'm forced to turn the volume down when idling otherwise it seems like my battery will just die. It does better when on the road but the lights still dim every time it hits a bass note.
I'm wondering what size alternator I should be upgrading to?
Old May 17, 2012 | 07:32 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: What size alternator?
You will have to find out which one you have and then get a higher amp one. You might also want a battery with the most cranking amps that you can fit in the battery box.
Old May 17, 2012 | 07:35 PM
iinversion's Avatar
Transmission: M5
I have the stock 105amp alternator right now. I have an Interstate battery that's relatively new but I don't know the cranking amps off hand, I'll have to look.
Old May 17, 2012 | 07:41 PM
Edwardgp's Avatar
Engine: 454-350
Well then all you need to do is go to the parts store and see what is available in a higher amp alternator. The biggest highest cranking amp battery you can fit in your battery box and that should do it.
Old May 17, 2012 | 07:52 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
105 is the highest "stock" alternator that I'm aware of, I know you can upgrade it to a 200amp model by sending it to an alternator rebuilder, but at idle they don't put out much more than the alternator does now, they only put out more amps at higher rpm. You can try raising your idle in gear by 200 or so and see if that helps out.
Old May 17, 2012 | 08:00 PM
iinversion's Avatar
Transmission: M5
Hmm what do you think about this alternator?
http://www.dbelectrical.com/p-9264-a...-firebird.aspx
Old May 17, 2012 | 08:02 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
i'd look into a CS144 swap,especially a late model 140
amp one-if that isn't enough,could go to a converted
CS144 of around 200a.I think a 140 amp stock one
in good health will do the job(could be something wrong
with you CS 130,causing weak output.The late style 140
amp CS144 can be found in a variety of 1990~2002GM
cars;'94-97LT1 f-bod,olds aurora,cadillacs,ETC.Different
brackets and other mods will be needed to fit in place
of CS130-depends on the year of 3rd gen the CS144
goes into,almost direct fit into certain '82-83 and 85-86
f-bodys with 15 or 17SI alternators.
Old May 18, 2012 | 12:34 AM
Stonehenge's Avatar
Car: 1989 5.7 IROC Dark Red/Blk 92Z28
Engine: 5.7
Transmission: 700R
Sounds like you need a capacitor.. Capacitors store a temporary electrical charge that can be released during periods of extra power strain. If a vehicle has dimming headlights when music is played, a capacitor could solve that problem... just google car audio capacitors.. Stone
Old May 18, 2012 | 01:20 AM
iinversion's Avatar
Transmission: M5
Yeah I actually orded a 2 Farad capacitor today so I'll see if that helps when I get it. I read about them and it seems to be more of a 'band-aid' than actually fixing the problem, but we'll see what happens I suppose.
I understand where you're going with that.. but I'd rather just buy an alternator that already fits and I can swap it out in like 20 mins tops without any extra hassles even if it does end up costing me like an additional $50 or whatever.
Old May 18, 2012 | 07:02 AM
Edwardgp's Avatar
Engine: 454-350
Let us know what works out for you iinversion.
Old May 19, 2012 | 01:30 AM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I had my stock 105 amp CS130 rewound at a local starter, generator, alternator shop and it now outputs 140 amps. It cost me about as much as a new alternator, but it keeps up with my 1400wrms system without any trouble, also has a lifetime warranty. The shop also put on a slightly smaller pulley to keep the voltage up during idle.
Old May 19, 2012 | 01:37 AM
Lt1Chris's Avatar
Car: 01 Acura TL
Engine: 3.2 Vtec
Transmission: 5 speed
Axle/Gears: ?
i hear capacitors hurt more then they help....so i just run a extra car battery with my system never seems to fail
Old May 19, 2012 | 04:46 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
or a CS144 - they came stock on some impalas and caddy's.
Cap won't help but a 2nd battery can't hurt (don't forget to install an isolator).
Old May 22, 2012 | 09:28 PM
iinversion's Avatar
Transmission: M5
Well I got the capacitor installed and I can say it did help a small amount, but the problem isn't gone. When everything is turned up the voltage drops as low as 11.5
I do like how the capacitor looks though so it wasn't a total waste of money xD
I think a new battery may be in order, suggestions?
Old May 22, 2012 | 10:31 PM
Banks4004's Avatar
Car: 1990 Camaro
Engine: 5.0
Transmission: T5 WC
I have a 1200w rms amp with 2 12s in my 1990 gm wagon with a 307. I upgraded to a 220 amp alternator and it helped a lot but still had problems until I got a 3 farad capacitor to go with it. Cap is good for hard hits and sudden draws of current, you need a good alternator first and foremost, but a loud system needs both.
Old May 23, 2012 | 12:36 PM
Stonehenge's Avatar
Engine: 5.7
Transmission: 700R
Optima Battery.. Stone
Nervous2
Oct 8, 2015 10:53 PM
J.C. Denton
Sep 21, 2015 04:23 PM
R13_Braz
Sep 18, 2015 05:00 PM
m00n420
Sep 11, 2015 02:39 PM
1Aauto
Sponsored Vendors
Sep 8, 2015 11:14 AM
